Brake problem
TimC
PostPosted: 13:52 - 20 Mar 2006    Post subject: Brake problem Reply with quote
The front brake on my cg is rubbing very badly, so bad that the front wheel dosnt want to turn Confused how can i loosten them? help need soon as test tomorrow Crying or Very sad
CB400sf version s, d&d race can and a few other odds and ends!
PostPosted: 17:27 - 20 Mar 2006    Post subject: Reply with quote
That a drum brake one? If so, it probably wants stripping down, cleaning and the pivots greasing assuming you haven't adjusted it yourself and overtightened the cable (in which case, back it off a bit). Worst case, the shoes are badly worn which can cause them to stick on.
You should be able to loosen them by pushing the lever on the brake drum.
I could do the job in half an hour. Wheel out, brake apart, good scoosh with brake cleaner, knock the cam out (if it is seized) and clean it with emery paper, grease the pivots then bung it all back on.
Where are you, I'm sure someone will be able to give you a hand if you are stuck and they are close enough.
If it is a disc brake, post back.
TimC
PostPosted: 18:24 - 20 Mar 2006    Post subject: Reply with quote
its the front disk,
White Noise
Mr Dudwee
PostPosted: 19:32 - 20 Mar 2006    Post subject: Reply with quote
sounds like you have a seized piston, take the calipers off and give them a good clean and inspection, hopefully that will sort it if not you may have to dig deeper and replace the seals
take a look here
https://www.bikechatforums.com/viewtopic.php?t=63228
HTH
WN
The last post was made 19 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 40.46 Kb
