| Valver |
 Valver World Chat Champion
| tonyyzf |
 tonyyzf Brolly Dolly
| Valver |
 Posted: 21:34 - 20 Mar 2006 Post subject: |
Cheers Tony
They arn't too bad but you can see a 3/4degree bend at the bottom of each. Are we talking getting them straight to 10 thou or less? or would straight 'by eye' do?
As for grinding them in, i've got a budding bike mechanic student waiting to do that for me. |
| tonyyzf |
| 0ddball |
 0ddball World Chat Champion
| Valver |
 Posted: 22:17 - 20 Mar 2006 Post subject: |
Husqvarna motard mate
Nightmare busting anything on this bike! I found some second hand ones on the Talsinracing site for £25 each but they were sold by the time i got round to phoning. Huskysport charge £108.10 and Talsin do them for about £1 less.
What happened? Well..................
I had just put a new bearing in the clutch and was fitting the basket bolts when i slightley over tightened one It had started to shear but seemed solid enough. Took the bike out for a quick burst and after about 20miles and at about 90mph.....WhrrrrrrrrrrrrrrBang! Back wheel locked up. It looks like the head of the sheared bolt and the washer behind it found there way to the cam chain, forcing it off the lower sprocket. Outcome - Two bent valves and slight heat scars in the barrel. |
| 0ddball |
| Valver |
| tonyyzf |
| Valver |
 Posted: 21:49 - 21 Mar 2006 Post subject: |
I phoned around a few engineering companys this morning and everyone i've spoken to has told me that impact straightening (ie with a hammer would excessively weaken the valve stem and may cause the base to shatter. Also advised that if the valve stem might stick or worse still cause massive power loss if the valve isn't seating perfectly. I've been warned of heat straightening too
Hmmmmm.... |
The last post was made 19 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
