Calling Mac OS 1337|\|355
fuzz
PostPosted: 10:24 - 22 Mar 2006    Post subject: Calling Mac OS 1337|\|355 Reply with quote
I need to find someway of shutting down a Mac (OS 10.4) after a certain time period. The way it needs to work, is to have the script check the last modified date of the antivirus folder. If it is less than 23 days, it ignores it and everything carries on as normal. Between 23 days and 29 days, it should display a message saying 'You have x days left' or something. On the 30th day, it should show a message 'Please return the laptop' and shutdown after a short delay. It needs to only work on a limited account, obviously not the root or admin account. My knowledge of UNIX and MacOS is utter shite to say the least, so any help on the matter is greatly appreciated.
Suzuki
Roger
PostPosted: 11:29 - 22 Mar 2006    Post subject: Reply with quote
Write a little script that checks the date of the folder, and does nothing if it's OK, or runs your shutdown/message script if it's too old.
Then add that script to cron, and set it to run every hour or something.
Could also add the script to a startup routine, so if it's too old it'll shutdown as soon as they start the laptop too.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
fuzz
PostPosted: 13:13 - 22 Mar 2006    Post subject: Reply with quote
I would write the script, but I can't Razz
But yes, that's the idea. It needs to run once when they log in on the limited account.
Suzuki
Roger
PostPosted: 13:25 - 22 Mar 2006    Post subject: Reply with quote
It needs to run periodically as well as when the first log in.
What if they log in before the period ends, and then just leave it logged in and turned on? Wink
I'd need access to the system if I was going to write your script for you.
fuzz
PostPosted: 13:31 - 22 Mar 2006    Post subject: Reply with quote
They wont.
I could probably write the script if I had pseudocode to work from. I can learn the commands by googling, but I have no understanding of UNIX at all (well, very, very little).
Suzuki
Roger
PostPosted: 10:30 - 26 Mar 2006    Post subject: Reply with quote
You still struggling with this? Or have you sorted it yet?
fuzz
PostPosted: 21:51 - 26 Mar 2006    Post subject: Reply with quote
I've written an Applescript that checks the date of a file, then warns or shuts down the system depending on the date. The trouble I'm having now is getting the script to run when the limited user logs in. I have set it to run at login, but it requires the user to click the app opening icon on the dock to run the script. If the user doesn't click it, it times out. If I can get it to run the script automatically, all will be well. I tried using osascript, but found out it doesn't like user interaction, i.e. display dialogs.
fuzz
PostPosted: 10:21 - 27 Mar 2006    Post subject: Reply with quote
So far I have:
set mainfile to "Macintosh HD:Applications:test.rtf" --set path to update file
set now to current date --gets todays date
tell application "Finder"
set filedate to modification date of file mainfile --gets last modified date of file
end tell
set Age to now - filedate --compare the file date with today
set daysleft to (30 * days) - Age --calculates days left to next update
set daysleft to daysleft div days + 1 --truncates days left, so increment by one
if daysleft < 1 then
display dialog "This iBook must be returned to ICT services and will no longer function until security updates have been installed." buttons "OK" giving up after 20 with icon 0
tell application "System Events"
shut down
end tell
else if daysleft < 7 then
set msgstring to "You have" & space & daysleft & space & "days left to return this iBook for updates."
display dialog msgstring buttons "OK" with icon 2
end if
I have tried executing it from a second script that calls it, but this doesn't seem to solve the problem of the app not opening from the dock.
Suzuki
Roger
PostPosted: 11:32 - 27 Mar 2006    Post subject: Reply with quote
Ooooh Confused
I've never use Applescript, so I will be completely useless to you now.
Perl I could have handled Wink
fuzz
PostPosted: 12:06 - 27 Mar 2006    Post subject: Reply with quote
I think Applescript was the wrong way to go. It does the job, but I cant run it from the limited account, even if I give it rwx permissions.
Suzuki
Roger
PostPosted: 12:19 - 27 Mar 2006    Post subject: Reply with quote
You'd probably be best writing a shell script.
If you're struggling with what the commands are, drop me a PM or MSN me. Smile
fuzz
PostPosted: 09:40 - 29 Mar 2006    Post subject: Reply with quote
Sorted it Thumbs Up I kept the Applescript but changed it around a little to get it to work with a login hook.
ali-b
PostPosted: 14:52 - 03 Apr 2006    Post subject: Reply with quote
You could probably use CRON to schedule checks (for login, and/or a timeframe).
There are loads of apps out there that GUI-ize the CRON scheduler.
I guess you're pretty much sorted, only just seen this so thought I'd suggest the CRON
A.
The last post was made 20 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 81.23 Kb
