SQL help needed
AcIdBuRnZ
PostPosted: 04:48 - 23 Mar 2006    Post subject: SQL help needed Reply with quote
Hi,
This has been doing my head in for hours....
It's failing at the line in bold
<?php
$department=$_POST['department'];
$manufacturer=$_POST['manufacturer'];
$name=$_POST['name'];
if (!$manufacturer)
echo '<center><hr>You must enter search criteria<br/>'
.'Please go back and try again<hr></center>';
exit;
mysql_pconnect('localhost', 'root', '') or die("Unable to connect to database");
mysql_select_db('valentines');
$sqlquery = 'SELECT * FROM $department WHERE manufacturer = $manufacturer';
$results = mysql_query($sqlquery)
or die("Could not execute query, please try again later");
while ($row = mysql_fetch_array($results)){
echo '<table width="100%" cellpadding="5" border="0">
<tr>
<td colspan=2 width=100% bgcolor=#990000><font color=#FFFFFF>'.$row[name].'</font></td></tr>
<tr>
<td rowspan=4><a href='.$row[image].'><img src='.$row[image].' height="150" width="150" /></a></td>
<td>Description : '.$row[description].'</td>
</tr>
<tr>
<td>Colours : '.$row[colours].'</td>
</tr>
<tr>
<td>Sizes : '.$row[sizes].'</td>
</tr>
<tr>
<td>Price : '.$row[price].'</td>
</tr>
</table>';}
if(mysql_num_rows($results)<1){
echo "<center><hr>No products found!<br>Please try again<hr></center>";
//mysql_free_result($results);
So basically it has a problem with the SQL query line. I suspect it's a problem passing the variables for some reason, as the query works if I enter the variable values manually.
Any suggestions?
simon1221
PostPosted: 10:03 - 23 Mar 2006    Post subject: Reply with quote
Try changing it to this:
$sqlquery = 'SELECT * FROM '$department' WHERE manufacturer = '$manufacturer'';
or die("Could not execute query, please try again later: " . mysql_error());
as it sometimes gets picky if you dont have '' on some parts of it.
The mysql_error() will help you to debug it if it still doesnt work, as it gives you the mysql error message, usually like "table 8923789 does not exist".
Suzuki
Roger
PostPosted: 10:25 - 23 Mar 2006    Post subject: Reply with quote
Here's your answer:
Code:
$sqlquery = "SELECT * FROM $department WHERE manufacturer = $manufacturer";
Basically it's the difference between single and double quotes.
Using single quotes, the string is exactly what you type. Using double quotes, variables are resoved to their values.
So, if $variable = "banana";
Then 'This is a $variable' will be the string This is a $variable.
Whereas "This is a $variable" will be the string This is a banana.
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
AcIdBuRnZ
PostPosted: 12:44 - 23 Mar 2006    Post subject: Reply with quote
Thanks for the help guys, but still having a problem. I had tried single and double quotes Confused
If I remove the die line after the query, then these are the errors that return:
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/hcrief07/public_html/valentines/search_result.php on line 65
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/hcrief07/public_html/valentines/search_result.php on line 84
Suzuki
Roger
PostPosted: 12:45 - 23 Mar 2006    Post subject: Reply with quote
What are the commands on lines 65 and 84 then?
AcIdBuRnZ
PostPosted: 12:49 - 23 Mar 2006    Post subject: Reply with quote
Just to add, I have other pages running queries on this database which work fine.
Just can't see where this is failing Mad
Could it be that the form isn't passing the values through Thinking I've checked every line of code, but from experience I know these problems are usually simple in the end!!! Confused
Appreciating the help guys Thumbs Up Smile
AcIdBuRnZ
PostPosted: 12:51 - 23 Mar 2006    Post subject: Reply with quote
I know there cannot be a problem with these lines though, as they work fine on other pages!!! Mad
Suzuki
Roger
PostPosted: 13:00 - 23 Mar 2006    Post subject: Reply with quote
You got MSN or something?
I don't have yahoo messenger.
PostPosted: 13:29 - 23 Mar 2006    Post subject: Reply with quote
I have a suspicion that it may be something like a null field causing problems.
Suzuki
Roger
PostPosted: 13:34 - 23 Mar 2006    Post subject: Re: SQL help needed Reply with quote
You have problems with that massive echo you've got too.
Code:
$row[image]
Should be $row['image'] since that should be an int or a string in the square brackets. The text alone is neither. You need some more quotes! Smile
Suzuki
Roger
PostPosted: 13:36 - 23 Mar 2006    Post subject: Reply with quote
Try this...
Code:
<?php
if (!$manufacturer)
exit;
<tr>
<td colspan=2 width=100% bgcolor=#990000><font color=#FFFFFF>'.$row['name'].'</font></td></tr>
<tr>
<td rowspan=4><a href='.$row['image'].'><img src='.$row['image'].' height="150" width="150" /></a></td>
<td>Description : '.$row['description'].'</td>
</tr>
<tr>
<td>Colours : '.$row['colours'].'</td>
</tr>
<tr>
<td>Sizes : '.$row['sizes'].'</td>
</tr>
<tr>
<td>Price : '.$row['price'].'</td>
</tr>
</table>';}
echo '<center><hr>No products found!<br>Please try again<hr></center>';
AcIdBuRnZ
PostPosted: 13:57 - 23 Mar 2006    Post subject: Reply with quote
Nope Sad
I have this other site running this PHP, which works fine:
<?php
$jobid=$HTTP_POST_VARS['jobID'];
if (!$jobid)
echo '<center><hr>You must enter a job number<br/>'
exit;
mysql_select_db('fastcabs');
$sqlquery = "SELECT * FROM jobs WHERE jobID = $jobid";
$results = mysql_query($sqlquery);
echo "<hr><p>Job ID : " .$row[jobID]. "<p>Driver ID : " .$row[driverID]. "<p>Customer name : " .$row[customer_name]. "<p>Date : "
.$row[pickup_date]. "<p>Time : " .$row[pickup_time]. "<p>Pick up address : " .$row[pickup_address]. "<p>Drop off address : " .$row[dropoff_address];
echo "<hr>";
echo "<font face=Arial size=+0><center><hr>That job ID does not exist<br>Please try again<hr></center></font><br>";
That is practically identical code - but it works!? Confused Cannot see why this one isn't Thinking
If I run the query manually on the database (i.e. inputing the variable values manually), it works fine:
SELECT * FROM ladieswear WHERE manufacturer = "Sasso"
Suzuki
Roger
PostPosted: 14:06 - 23 Mar 2006    Post subject: Reply with quote
Something is obviously different. Wink
Have you tried my corrected version yet?
AcIdBuRnZ
PostPosted: 14:13 - 23 Mar 2006    Post subject: Reply with quote
OK, I've narrowed it down a bit.
Seems to have a problem with the WHERE command? Confused
This works fine, only when I add in the WHERE part does it have a problem:
$sqlquery = "SELECT * FROM $department";
Obviously it is OK with using the variables. Just don't understand it.
AcIdBuRnZ
PostPosted: 14:14 - 23 Mar 2006    Post subject: Reply with quote
Yes. Exactly the same problem Sad
PostPosted: 14:24 - 23 Mar 2006    Post subject: Reply with quote
Try writing the sql string to the screen and see what it is passing.
AcIdBuRnZ
PostPosted: 18:32 - 23 Mar 2006    Post subject: Reply with quote
Sorted! Thumbs Up Smile
It will only process the SQL query like this:
$sqlquery = "SELECT * FROM $department WHERE `manufacturer` = '$manufacturer' AND `name` = '$name'";
Don't know why it needs the ` `?
Is it dependent on the version of MySQL? Confused
PostPosted: 18:52 - 23 Mar 2006    Post subject: Reply with quote
Wouldn't think so. Very strange syntax. Unless someone set the table up with column names surrounded by inverted commas.
AcIdBuRnZ
PostPosted: 19:01 - 23 Mar 2006    Post subject: Reply with quote
It was myself that set up the table Confused
Didn't do anything different. Can't suss it out, so will just need to accept that's the way it is going to work Neutral
AcIdBuRnZ
PostPosted: 19:23 - 23 Mar 2006    Post subject: Reply with quote
What's even stranger, is I decided to remove the `` from the query... and it still works!!!? But it wouldn't earlier? Confused
Meh........
simon1221
PostPosted: 20:55 - 23 Mar 2006    Post subject: Reply with quote
Shouldve used the mysql_error function Doh! but oh well you got there in the end.
Suzuki
Roger
PostPosted: 09:59 - 24 Mar 2006    Post subject: Reply with quote
If the names of columns are 'special name', such as "order" or "select" etc, then you need to surround the names in backticks to get the SQL to work.
Sorry, should have noticed that earlier. Embarassed
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 137.79 Kb
