Hard to take rear wheel off? - 2003 hornet
Keeno
PostPosted: 17:59 - 26 Mar 2006    Post subject: Hard to take rear wheel off? - 2003 hornet Reply with quote
Hi all
Had to come home early today after discovering a nail in my rear tyre. I have the bike up on a paddock stand and im going to remove the rear wheel to take it and get the puncture repaired. Im waiting on a m8 to come round with some tools before I make a start on it.
I was wondering if removing/refitting the wheel will be difficult? Im not the most mechanically minded person Sad but not a total dumbass either. Any tips or advise?
Keeno
NSR-Rulez
PostPosted: 18:03 - 26 Mar 2006    Post subject: Reply with quote
it's not too hard, just remember to make sure the rubber bits where the wheel attaches to the swing arm are still there when you get the wheel back, (i think they are called the cush rubbers, probably wrong)
NSR-Rulez
Past: 1985 Suzuki GS 125 + 2002 Honda NSR 125 R-2 + Ford Fusion
Present: Honda CBR 600 RR-5 + Suzuki SV650S-K4 + Mitsubishi FTO GPX
craigs23
Mr Muscle
PostPosted: 18:17 - 26 Mar 2006    Post subject: Reply with quote
Most tricky part is getting the brake assemberly and all the spacers lined up.
Easier with two people (one holding/adjusting the wheel and checking the spacers with someone else tapping in the spindle. Or use a block of wood/foot to support the wheel whilst installing.
I miss how easy it was on my RVF...
Keeno
PostPosted: 20:21 - 26 Mar 2006    Post subject: Reply with quote
Well got it off
Wasnt too difficult and I must say im pleased that i got it done, considering it was getting a bit dark and was pissing down.
Im left with the following :
Keeno
PostPosted: 20:22 - 26 Mar 2006    Post subject: Reply with quote
I take it that the two washer type things on the piece of paper are the cush rubbers you are taling about NSR?
Will it be difficuly putting the caliber back on? im not sure if it will be locked closed?
0ddball
PostPosted: 03:12 - 27 Mar 2006    Post subject: Reply with quote
No, the cush rubber looks like this https://images.google.co.uk/images?q=tbn:sBq5FxoTIV0xQM:www.shop.bevelheaven.com/images/cush-rubber.jpg
Those bits are mearly spacers. Putting it back together should be a 5 min job. Just make sure you don't press the brake pedal until the caliper is back on the disc and it should slide back on easily.
Guest
PostPosted: 06:50 - 27 Mar 2006    Post subject: Reply with quote
Download yourself the Hornet maintenance manual for nowt from here https://www.manualclub.com/Motorcycle_Manuals/Download/Honda/orderby,2/page,3/
Keeno
PostPosted: 18:07 - 27 Mar 2006    Post subject: Reply with quote
All went back together fine Smile Bloody awkward though having to hold the wheel in place with my foot.
Keeno
PostPosted: 21:30 - 27 Mar 2006    Post subject: Reply with quote
Just one more thing before this thread disappears. When i took the wheel off there was no cush rubber and there is no mention of it in the service manual (thanks for the link guest).
I hope im not missing something?
bigedyant
PostPosted: 19:22 - 29 Mar 2006    Post subject: Reply with quote
Did the sprocket fall off and go bowling off across the garage like mine does? if not you may not have seen the Cush drive behind the sprocket.
It is better to remain silent and be thought a fool, than to open your mouth and remove all doubt.
Guest
PostPosted: 19:35 - 29 Mar 2006    Post subject: Reply with quote
If the sprocket carrier didn't fall out then you can assume that the cush rubbers are ok Thumbs Up
craigs23
Mr Muscle
PostPosted: 20:25 - 29 Mar 2006    Post subject: Reply with quote
Might have been worth checking/greasing them once the wheel was off anyway, just to be sure.
Keeno
PostPosted: 21:27 - 29 Mar 2006    Post subject: Reply with quote
I know what it is now, i misunderstood 1st time round, i thought the cush rubber was a similar size to the washers.
The sprocket came off when the guy was fixing the puncture and I remember seeing the cush rubbers then.
What exactly do they do? Im planning on taking the wheel of again soon, and to give the bike a real good clean and i'll also grease everything then.
Guest
PostPosted: 21:34 - 29 Mar 2006    Post subject: Reply with quote
They absorb the shock of gearchanges so as not to pass it on to the sprocket or wheel. Watch a bike next time you're next to one and he puts it into gear - you'll see the sprocket move even though the wheel doesn't. The cush rubbers are 'giving' a little to smooth it out.
Rule of thumb - if you've had the wheel out and you need to stand on the sprocket to push it back in then they're ok. A squirt of WD will help if they're very tight. No need to grease them as such as they don't move and don't seize in. If you can push the sprocket carrier back in easily they're sugared.
To check in-situ, hold the sprocket at 'quarter to three' and try and move it like a steering wheel. If it moves easily or feels loose they've gone.
Keeno
PostPosted: 21:55 - 29 Mar 2006    Post subject: Reply with quote
Something i did notice since ive put the wheel back on is that when I let the clutch out in 1st (as im getting the biting point), theres a slight jolt that i never noticed before.
I put this down to my imagination but could it be more?
Thanks for all the advise btw, i really appreciate it. Im new to any type of maintenance work so all your comments are proving to be really handy.
fazed
Korn is my hero!
PostPosted: 21:58 - 29 Mar 2006    Post subject: Reply with quote
Check the chain is tensioned correctly, I presume you adjusted it at the tightest point of the chain ?
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
Keeno
PostPosted: 22:26 - 29 Mar 2006    Post subject: Reply with quote
Adjusted what? The wheel position?
The last post was made 20 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 89.25 Kb
