TT600 Indicator Not Working
stowen
PostPosted: 20:04 - 26 Mar 2006    Post subject: TT600 Indicator Not Working Reply with quote
Hi, I've just taken delivery of a W/2000 reg, TT600 and appear to have a faulty front r/hand indicator. Bulb's not faulty (swapped it with one of the others), I've got voltage as I'd expect.....but the lamp will not light.
Unfortunately, I've got large hands and I can't get under the faring to disconnect the leads to pull the entire thing out.
Any ideas on how to take the faring off, or if anyone else has had this issue before and fixed it with some double sided tape or something? (I hate to take the bike in to Triumph only to ask them to fix this!)
Thanks.
StoweN
craigs23
Mr Muscle
PostPosted: 21:00 - 26 Mar 2006    Post subject: Reply with quote
Could it just be the indicator connector's come loose? Are the others okay? Does the rear indicator come on but stay on?
stowen
PostPosted: 21:11 - 26 Mar 2006    Post subject: Reply with quote
Hi, the others all come on - the rear (same side) flashes at normal speed. I've checked the connection and it seems ok as there's voltage....don't understand to be honest.
StoweN
colin1
Captain Safety
PostPosted: 21:21 - 26 Mar 2006    Post subject: Reply with quote
check the connection where the indicator is connected to the wiring loom
if you dont wanna do it with the fairing on, take the fairing off
you just undo the screws with an allen key
also check that the contacts to the bulb are as they should be and not bent out of place so they arent touching it properly
stowen
PostPosted: 00:33 - 02 Apr 2006    Post subject: Reply with quote
All sorted....thanks to everyone.
StoweN
The last post was made 19 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 42.3 Kb
