Does anyone know the size of the copper washers for banjo
mylow
PostPosted: 13:55 - 27 Mar 2006    Post subject: Does anyone know the size of the copper washers for banjo Reply with quote
Does anyone know the size of the copper washers for banjo bolts, also what would the torqe settings be, thanks for your help peps
BSM Rider Traing, CBT's DAS and Instructor Training 01454 658 325
sickpup
Old Timer
PostPosted: 13:59 - 27 Mar 2006    Post subject: Reply with quote
Brake specific size. ie not available except as a 'brake copper crush washer'.
swampy
PostPosted: 17:30 - 27 Mar 2006    Post subject: Reply with quote
You can anneal the copper washers if you still have them, and reuse. Heat them to cherry red with a blow torch (or gas hob), and then quench them in a jar of water. This softens the copper, and allows it to be pliable enough to provide a seal when next used. Thumbs Up
mylow
PostPosted: 15:30 - 29 Mar 2006    Post subject: Reply with quote
does anyone know what size thew washers are tho, I must have lost the other ones, as they are no ware to be found and my old man is going to get them
Bezzer
PostPosted: 15:36 - 29 Mar 2006    Post subject: Reply with quote
You've got the banjo bolts, measure them or take one with you when you go and get the washers, there are different sized bolts you want them for YOURS.
MikeH
PostPosted: 20:57 - 29 Mar 2006    Post subject: Reply with quote
If in doubt, you can get mixed packs of copper washers from most motor factors Wink
Busa Junkie
The last post was made 20 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 47.16 Kb
