Problems with a Wavey disk.
Akiraprise
PostPosted: 14:00 - 28 Mar 2006    Post subject: Problems with a Wavey disk. Reply with quote
Hey, I've been having so much problems with my rear wavey disk on my rs125, here's the problems:
I fitted the wavey disk, and every time I brake theres a REALLY powerful wobbly feel through the pedal, I think that's due to the waveyness- of the disk, however it's so powerful I can barely use it to brake.
Next thing, my retaining clip snapped and the pads were free, got caught in the caliper in a stupid position and completely wrecked the disk, burnt pads and metal score marks everywhere.
The garage then grinded the disk down so it's smooth, and tightened the bolts (they came out) but it's still really dodgy.
I've taken the caliper off, cleaned everything, new pads, re-bled the system, also new pin, circlip and retaining pin.
The pedals still got SO much travel though, and barely any brakes. It's realyl frustrating, please help - what could it be?
16,000km RS125 Racing - if it's any interest
TA!
PostPosted: 14:09 - 28 Mar 2006    Post subject: Re: Problems with a Wavey disk. Reply with quote
You say 'RS125' Racing, I presume this isn't a GP bike as you give the 'mileage' in distance.
I'm also presuming it's not actually a race bike, so is just a road Aprilia RS125?
If there's loads of travel in the pedal, then it probably needs to be bled 'better'.
Wavey discs shouldn't give an odd feeling - they should be just as smooth as normal discs.
If you're still getting this, there's probably a problem somewhere else.
RI_HA
PostPosted: 14:09 - 28 Mar 2006    Post subject: Reply with quote
im no expert but wavey disks?
do you mean the disc feels wavey instead of smooth?
if this is the case i suggest you bin them and have them tottaly replaced as they will be warped, this is quite dangerous and probably why you are getting so much shudder when you break.
Black Knight
PostPosted: 14:21 - 28 Mar 2006    Post subject: Reply with quote
Wavey discs are simply a straight swap. TBH is unlikely you would notice any difference in a road application.
Sound like something hasn't been fitted correctly to me.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
veeeffarr
PostPosted: 14:25 - 28 Mar 2006    Post subject: Reply with quote
This is a wavey disc:
https://www.dirtbikestore.co.uk/acatalog/waveyDisc.jpg
RI_HA
PostPosted: 14:35 - 28 Mar 2006    Post subject: Reply with quote
cheers toby, didnt know they were an actual name of a disk Embarassed
I thought he meant that they were actually wavey as to no be flat like brakes should be
i stand corrected Thumbs Up
veeeffarr
PostPosted: 14:38 - 28 Mar 2006    Post subject: Reply with quote
Just don't ask me what the fuck the difference is between them and standard discs! Because then I will look really stupid! Something to do with heat disperal?
Akiraprise
PostPosted: 14:56 - 28 Mar 2006    Post subject: Reply with quote
Not meaning the disk itself is pitted, I meant the disk is of a wavey kind, like Toby posted.
And the name 'RS125 Racing' name is the model, ie Extrema, Racing, and that new one. It's a road bike, not a GP bike lol.
The garage is re-bleeding it tomorrow.
Are the pads supposed to be a little wobbly when not pressed into the disk
Wavey disks: They look cool - the main reason I got it Razz, heat dispersal and less rotating mass.
finpos
Suggested solution:
1. Take tarty wavey disk.
2. Throw in bin
3. Replace with properly manufactured/tested oem item (or pattern part)
4. braking harmony restored.
kids these days etc.
finpos.
PostPosted: 15:18 - 28 Mar 2006    Post subject: Reply with quote
Suspect that there is air stuck by the brake light switch banjo bolt, which is the highest point in the system on the RS125.
Does sound like the disk is warped. Possibly related to using the disk when it was not bolted in place correctly.
Main advantage of a wavey disk is mean to be that they slice off the top layer of the pad. Doubt they are any better for heat dissapation.
Pads should have a tiny amount of play in the caliper when the brakes are not applied.
Guest
Check that the mounting faces of the disc and the wheel are scrupulously (sp?) clean - any bit of crap trapped between the two will throw the business area of the disc out of true and provede the symptoms you describe.
They might look good but any improvement over standard discs is imagined I reckon - fashion statement only Wink
Akiraprise
PostPosted: 19:18 - 28 Mar 2006    Post subject: Reply with quote
I'm going to give Kickstarts and Guests advice a go, both seem very plausible.
I presume to get that air out I can't just bleed the brakes more, but have to take that part off, and put it lower than the caliper? Would that work or's that just a plain stupid idea - I haven't looked to see if that's possible yet though.
About the disk being warped - I asked the garage this, they had a quick look at it and said they doubt it's warped, but will do some test to make sure, it's i think around a centimetre thick steel, so would be very hard to warp from just the rear brake? Although the loose screws wouldn't help.
Guest - That's quite a good point actually, I cleaned the wheels whilst they were off but didn't really check that region, I think they were clean, but could've got loads of crap in with the loose bolts.
I shall see tomorrow - it's going back to the same garage and they'll hopefully sort it FOC, I'll keep you all updated.
element
PostPosted: 19:36 - 28 Mar 2006    Post subject: Reply with quote
if the disc is warped youd feel pulsing in the pedal... You'd feel the the wheel binding when using the brake too... Dead easy to check... Bike on center stand and spin the back wheel while looking at the disc spin in the caliper Smile (might want someone to hold the front on the bike mind)
I wouldnt dismiss the possibility of a warped/bent disc because it sure does sound like it..
Smile
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
BFG
PostPosted: 20:03 - 28 Mar 2006    Post subject: Reply with quote
Warp test -
Duct tape a pencil firmly to the swing arm so the point is close to the outside edge of the disk and the pencil won't move.
Get the back wheel off the floor, and spin the wheel by hand. Look at the distance between the pencil point and the edge of the disk. If the disk looks like it going in and out, it's knackered. Smile
PostPosted: 23:06 - 28 Mar 2006    Post subject: Reply with quote
Best thing to do is cover everything around the rear brake master cylinder with cloth to protect it from the brake fluid. Put pressure on the rear brake lever and then crack off the banjo bolt / brake light switch (on the RS the banjo bolt is also the brake light switch, operated by fluid pressure) and tighten it again then release the brake lever. Do this a couple of times. Wash off any fluid that has spilt.
element
PostPosted: 18:30 - 29 Mar 2006    Post subject: Reply with quote
Adding to that I tie my lever (I have a scoot so I dont have a pedal operated rear brake but you'll think up some method) to the bars keeping the lever depressed.. I leave it like that overnight and in the morning I'll find that I can pull the lever even closer to the bars. Thats a good thing cos all the any air bubbles will have should have moved down the the system.Then keeping the lever depressed at max i'll bleed off that last bit of air, tighten the nipple and give the lever a few pumps. You'll find the brake will be a LOT better Thumbs Up
Another bit of advice I was given was to release the lever very slowly after tightening the nipple Smile
Guest
PostPosted: 19:24 - 29 Mar 2006    Post subject: Reply with quote
Air that is heavier than liquid? You must live in a parallel universe Wink
element
PostPosted: 03:01 - 30 Mar 2006    Post subject: Reply with quote
My next door neighbour is a bike mechanic for a local shop that specialise in sportsbikes and im sure thats what he told me when he said about tieing my lever to the bars overnight.
How do u explain the fact I can bleed more air out of the system?
PostPosted: 11:40 - 30 Mar 2006    Post subject: Reply with quote
Brake fluid is bad for getting lots of tiny bubbles if you shake the bottle before use (DOT 5 is even worse for this). Suspect that given time these bubbles join up to become visable ones, possibly helped by the system being under pressure. I cannot see how when it is just under pressure the light air will sink to the bottom of the system (and if it did you would never get it out of the system and the bleed nipple is on the top of the caliper normally).
finpos
PostPosted: 12:11 - 30 Mar 2006    Post subject: Reply with quote
The theory behind the tie-back-the-brake-lever thing is that overnight all the little air bubbles gather and rise to the top i.e. into the master cylinder itself. Then when you release the lever in the morning, the collected air gets flushed into the reservoir.
Not sure how well it works - especially if you have dirty great air pockets in your pipes as opposed to little bubbles dispersed throughout the fluid.
finpos.
The last post was made 20 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 112.86 Kb
