Kawasaki Zxr 750 1994/1995
kelvin_r6
PostPosted: 02:01 - 29 Mar 2006    Post subject: Kawasaki Zxr 750 1994/1995 Reply with quote
Hi one and all. i own a kawasaki zxr 750 and i am having a few problems with her.
First is sometimes she will start fine but other times i have to bump start her. when i puch the strat button i get a "tick tick" noise comes from around under the seat area.
the other problem is that my battery sometimes charges and other times it will not charge at all.
if anyone could point me in the direction of where to start i would be very greatful
Many thanks kelvin Razz
colin1
Captain Safety
PostPosted: 03:42 - 29 Mar 2006    Post subject: Reply with quote
im no expert but maybe a problem with the charging system like the rectifier
you could put the battery on charge each night to keep it topped up until you get the rectifier fixed
might be something else though
Whosthedaddy
PostPosted: 09:52 - 29 Mar 2006    Post subject: Reply with quote
This was happening to my 91 ZXR, the bike would only hols a charge for a short time then need to be jumped all the time.
It turned out that the altenator was shagged.
The mechanic thought that he may just need to replace the rec / reg (cost about £30) but it appeared to be almost permenantly mounted to the actual altenator Thinking
I sourced a second hand altenator from ebay for £45 inc P&P Thumbs Up The actual lot was for the whole engine, but after a quick email, he removed it for a seperate sale Razz
The garage only charged £60 to complete the job.
These parts are getting harder to find. One salvage place in Bristol wanted £92 for an altenator and a brand new one around the £500 mark Shocked
Hope this helps
kelvin_r6
PostPosted: 17:46 - 29 Mar 2006    Post subject: Reply with quote
thanks guys will have to try and test the alternator and stuff. anyone know anuthing on the starting problem?
Thanks Laughing
Whosthedaddy
PostPosted: 17:53 - 29 Mar 2006    Post subject: Reply with quote
Its the ckicking of the starter motor
kelvin_r6
PostPosted: 18:56 - 29 Mar 2006    Post subject: Reply with quote
i just got otu my namual whipped off the seat and side panle and tried to start the bike. the clicking was coming from the starter relay so i think thats the problem.
better get looking for a starter relay and starter motor Sad
Guest
PostPosted: 19:34 - 29 Mar 2006    Post subject: Reply with quote
Probably not - the starter relay clicks because it's not getting enough volts (sort of)
When you thumb the button the relay pulls in and away you go. If the battery is low, then the relay pulls in and all the juice flows to the starter motor, and this causes the relay to drop out again. The volts then pick up and (assuming you're still thumbing the button) the relay pulls in again. The volts drop and the relay drops out etc. etc. etc.
Look at your battery first - are the connections clean and tight? A good battery won't start your engine with poor connections, nor will the alternator re-charge it.
If the battery is good put a voltmeter (set on the 20 volt DC scale) across it's terminals - you should get around 14.5 volts when revving the engine to around 5000 rpm. If not, then it's time to start looking at your charging system.
Always start with the cheapest fix first Wink
kelvin_r6
PostPosted: 04:19 - 31 Mar 2006    Post subject: Reply with quote
does anyone know if any of model zxr alternator will fit on my bike?
Thanks kelvin
Kris
PostPosted: 14:32 - 31 Mar 2006    Post subject: Reply with quote
I had an earlier zxr750, the '89 H1 model. When my battery was shagged I heard the very same 'click-click' that you describe, which as said previously, was the starter relay. It turns out that zxr's are particularly fussy about how many volts are required to turn over the engine. One or two volts down and she didn't want to know. Get your battery checked out - maybe it's had it.
www.prisonplanet.com
Barry_M2
PostPosted: 15:23 - 31 Mar 2006    Post subject: Reply with quote
Kelvin - Good choice of bike mate, plus, going from your location on the map in your profile, your quite close to me?! (St Albans)?
If your still stuck mate, I dont mind popping over and taking a peek, two heads better than one so they say!
I've had a couple of L model ZXR's and now got an M2.
Let me know.
kelvin_r6
PostPosted: 20:15 - 31 Mar 2006    Post subject: Reply with quote
Thanks for the reply's guys.
Barry_MC21 yer i live in mill hill mate. i replaced the battery a few months ago cos it was shagged.
i got all my tools robbed not to long ago and i cant check the voltage trying to get hold of a multimeter.
Barry_M2
PostPosted: 02:58 - 01 Apr 2006    Post subject: Reply with quote
Mill Hill is about 20 mins away.
If you want a hand chief, just let me know.
Guest
PostPosted: 08:59 - 01 Apr 2006    Post subject: Reply with quote
Maplins do one for under a fiver. In fact they sometimes have a 'two for the price of one' offer. I keep one under the seat and I've used it three times on the road up to now Thumbs Up
kelvin_r6
PostPosted: 18:21 - 02 Apr 2006    Post subject: Reply with quote
just tested my battery reving the bike to 5000rpm and it shows up 14.5 on the multimeter.
what do you suggest i test now?
got the multimeter for a £5 from maplins Thumbs Up
Thanks
Barry_M2
PostPosted: 20:08 - 02 Apr 2006    Post subject: Reply with quote
Kelvin,
It could be a couple of things.
First, when you hit the starter and it just clicks, have a look at the neutral and oil lights on the dash, do they dim and almost go out, then back to full brightness when you release the starter?
If so, then its a bad earth, either on the battery or the frame.
The other thing is, it could be the starter relay, thats the clicking under the seat, replace the relay and see if it fixes it.
bidman
PostPosted: 20:17 - 02 Apr 2006    Post subject: Reply with quote
Hey, pretty sure your battery is nakered mate. The ticking sound is the starter relay not getting enough power to keep the terminals connected so bouncing back and fourth. Although your battery may be showing a voltage, there may be no power coming from the battery. I had a battery sowing a good 12v yet it did nothing, not even light a bulb, so I measured the amps and there were none at all. If your battery is fairly new and it is damaged check your regulator/rectifier to make sure you don't kill your new battery.
hope this helps, Dan Thumbs Up
Don't ride it, RAG IT!!
kelvin_r6
PostPosted: 23:01 - 02 Apr 2006    Post subject: Reply with quote
when the bike DONT start and just clicks the nuetral lights DO NOT dim down or go out.
the battery is about a month old i think im gonna go get it tested to make sure or can i test it on a multimeter?
gonna test the start relay as well. but would that be stopping the battery from charging?
the battery is able to light all my lights up when the bike aint running.
bidman
PostPosted: 09:30 - 03 Apr 2006    Post subject: Reply with quote
Ok, hook up your cars battery with jump leads to your bike if the bike starts up with no problems due to the power of the other battery then your battery needs replacing. It could be that you have a faulty regulator/ rectifier that has overcharged the battery and damaged the cells, or you could just have bought a dodgy battery or not charged it at the correct rate the first time it was used.
Hope this helps Dan Thumbs Up
kelvin_r6
PostPosted: 23:22 - 29 Apr 2006    Post subject: Reply with quote
hi all, put the starter leads on my mums car and it started to do the clicking noise so it could be the regulator/rectifior?
Thanks
The last post was made 20 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 99.78 Kb
