spraying plastic pannels
shager
PostPosted: 23:11 - 29 Mar 2006    Post subject: spraying plastic pannels Reply with quote
i am going to attempt to spray the pannels on my bike as they mave fadded
any siggestions on how to do it???
alains
PostPosted: 23:21 - 29 Mar 2006    Post subject: Reply with quote
clean all old paint , sand it a bit , they a pre-lay with plastic first lay special (i do not know the english name) then 2 or 3 lays of paint and if you use metallic paint a lay of varnish
kat250
PostPosted: 23:31 - 29 Mar 2006    Post subject: Reply with quote
If they have just faded spend abit of time with t cut it should bring the colour back out if you spend enough time doing it. Cheaper and maybe easier than a spray job. And it will porbably look better.
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
code guru
PostPosted: 23:34 - 29 Mar 2006    Post subject: Reply with quote
sand your old pain off or strip it off, put 3 layers off primer allow about 1h 2 dry each layer, then smoth it off with some wet and dry 1200 sand paper and wash with some warm soapy water, leave 2 try then spray 3 layers off paint allow about 1h again for each layer and rub it down with 1200 paper , wash with warm soapy water then wait for them 2 dry then laquer it, btw wait for the paint 2 dry for at least 1 day somewere warm before u rub it with some 1200 paper, 1200 paper is very fine, its there 2 take the shine off and the laquer adds the shine back but at the same time it acts like a harder, thats how i did mine and they come out fine, just need 2 take your time
ZRX61
Victor Meldrew
PostPosted: 01:03 - 30 Mar 2006    Post subject: Re: spraying plastic pannels Reply with quote
Ignore the 3 posts above this one for starters......
First thing to do it decide if it can be restored. Use a paint cleaner like the one Mequiars sell.... Do NOT use TCut... EVER.
Next use a polish & finally a wax. If those 3 steps don't bring it back then it may need refinishing.
Report back.
Jubal
PostPosted: 14:28 - 30 Mar 2006    Post subject: Reply with quote
Whats wrong with T-Cut? Iv'e used it for years without a problem.
ZRX61
Victor Meldrew
PostPosted: 18:09 - 30 Mar 2006    Post subject: Reply with quote
It's fine if you like trying to get a shine by using liquid sand....It's probably the worse product for restoring a shine you could possibly use. It restores color, but it totally fucks the finish.
It's the tool of clueless bodgers. Rolling Eyes
Jubal
PostPosted: 22:09 - 14 Apr 2006    Post subject: Reply with quote
I agree, if you you go at it like a Ham-fisted jerk.........I know how to use it so don't have the problems which you seem to have.
ZRX61
Victor Meldrew
PostPosted: 00:34 - 15 Apr 2006    Post subject: Reply with quote
It doesn't matter how you use it, it still contains enough abrasives to fuck up a finish. The idea is to have NO scratches in the paint, not replace a few large ones with a bunch of smaller ones.
Jubal
PostPosted: 20:16 - 15 Apr 2006    Post subject: Reply with quote
I see no scratches-
https://img.photobox.co.uk/4778984523a1a3a84ab6aa80321a8c26b8012865cd0d60ecd909b947.jpg
ZRX61
Victor Meldrew
PostPosted: 00:43 - 16 Apr 2006    Post subject: Reply with quote
Could you possibly post an even smaller resolution picture? Rolling Eyes
NC30UK
PostPosted: 00:57 - 16 Apr 2006    Post subject: Reply with quote
Depends if the paint is laquerd or not.
T-Cut will just create millions of tiny scratches in the laquer and will do nothing to the paint underneath.
If the paint is unlaquerd then ultra fine autosol or T-Cut will flat it down and bring the colour back.
Jubal
PostPosted: 13:50 - 16 Apr 2006    Post subject: Reply with quote
https://img.photobox.co.uk/951577303bfa4561a47bcfc59f501328f10513d023baf0b305507c0d.jpg
Sarge-Devil
PostPosted: 14:18 - 16 Apr 2006    Post subject: Reply with quote
Use a T-Cut..then a finer cutter...and finally some good polish to bring back the shine
2006 Blue Honda Hornet 600
ZRX61
Victor Meldrew
PostPosted: 18:51 - 16 Apr 2006    Post subject: Reply with quote
Yay! finally someone posts something inteligent! Altho there are FAR better options that T Cut. You're on the right track tho.
Jubal
PostPosted: 23:01 - 16 Apr 2006    Post subject: Reply with quote
ZRX61, are you a paint sprayer?
If so, can we see some examples of your superior work?
ZRX61
Victor Meldrew
PostPosted: 01:36 - 17 Apr 2006    Post subject: Reply with quote
Sure, heres one:
https://img.photobucket.com/albums/v317/ZRX61/Spitfire.jpg
But I also had to restore it from a crashed wreck before I painted it.
Jubal
PostPosted: 02:03 - 17 Apr 2006    Post subject: Reply with quote
Sure, heres one:
Very good but I don't see much relevance to motorcycle paintwork there.
I see from your albums that you also like playing with model aircraft as well.
ZRX61
Victor Meldrew
PostPosted: 02:10 - 17 Apr 2006    Post subject: Reply with quote
Maybe you'd care to explaint io everyone the difference between painting a few square feet of sheet metal & a few hundred sq ft of sheet metal?.. apart from the area aspect that is..?
Er, no, where'd ya get that idea? There are some pics on there of drone engines that I hosted for a friend so he could post them elsewhere, the red 2& 4cyl ones, Is that what ya talking about? If so those things are about 2.5 feet across. The little V8 is a scale Liberty engine, it runs & cost $7500. It's actually for sale if you'd like to buy it?
Jubal
PostPosted: 02:18 - 17 Apr 2006    Post subject: Reply with quote
Area aspect no different, quality of finish on the example shown very much different.
No not interested in Liberty engine thanks.
DynaMight
PostPosted: 02:25 - 17 Apr 2006    Post subject: Reply with quote
Sure, heres one:
Did you use one of these Wink
https://www.paintquality.com.au/press/press_images/DIY_PG_Apr03/Roller_col.jpg
ZRX61
Victor Meldrew
PostPosted: 02:34 - 17 Apr 2006    Post subject: Reply with quote
LOL! Bloody Air Force insisted the finish look EXACTLY the same as the way it was the day it left the factory. It's DuPont Centari with the catalyst left out to flatten the finish.
I'm trying to find a pic of the red Vette I did with the strawberry pearl & ghost flames...
Edit: I think I used some old Binks paint cannon on the Spit....
The last post was made 20 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 115.48 Kb
