'Oil' in Coolant Expansion Tank
Alastair
PostPosted: 10:01 - 30 Mar 2006    Post subject: 'Oil' in Coolant Expansion Tank Reply with quote
While I'm still waiting to get the engine re-build back I was giving the bike a bit of a check over and clean yesterday. The engine is obviously out and I drained the coolant to do that but never before looked at the expansion tank.
When I took the rubber stopper out of the top yesterday I noticed that it was full (within the level marks) of black oily fluid. It didn't really smell like oil however but was slimy. As a result the tank is not clear anymore so I thought is was empty as it looks like nothing is in it but it's actually coated in crap.
I should be getting the engine back within a week so am wondering what I should do with this? Take off the tank, drain and clean? What about the pipe that comes into it should I try and flush that too?
Bike is a Yam TDR by the way but is the same set up as a DT/R or TZR.
Any advice appreciated and also explanations as to why it would be black now instead of normal coolant.
I blame the previous owner Wink
finpos
PostPosted: 11:36 - 30 Mar 2006    Post subject: Reply with quote
In my experience, black oily fluid is usually.... oil.
Possibly a sign that the engine has had a head gasket failure (4 stroke?) when you may get oil in the coolant, coolant in the oil, or both, depending on the engine. But it seems like you're having a re-build, so don't worry.
If it's a two-stroke, then that's a bit odd, but could be down to a gasket failure somewhere else.
Just clean it out with de-greaser - hot soapy water if you are desperate. Put some gravel in it as well and shake it to buggery. Oh and make sure you have all the soap and gravel out before you re-fit it!
finpos.
Alastair
PostPosted: 11:43 - 30 Mar 2006    Post subject: Reply with quote
Very Happy Thanks for the tips. I wouldn't leave any gravel or soap in don't worry!!!
It's a 2-Stroke so still dunno what's caused it. Think I better clean out as many tubes and pipes as I can too.
This bike is a damn lemon Sad
Davo
Davo To The Rescue!
PostPosted: 12:40 - 30 Mar 2006    Post subject: Reply with quote
If I remember rightly, I'd probably look at the seal around the water pump.
Obviously drain the reservior and flush it through with some clean water.
Alastair
PostPosted: 13:02 - 30 Mar 2006    Post subject: Reply with quote
Thanks for that, I'm hoping the mechanic knows enough about what he's doing that he'll be giving me back a 100% engine but I'll mention it to him anyway.
ZZR-Souls
PostPosted: 13:31 - 30 Mar 2006    Post subject: Reply with quote
And don't just fill it with water. Use a proper engine coolant that is either bright green or bright pink. That way you can see easier if it need topping up.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
Alastair
PostPosted: 13:33 - 30 Mar 2006    Post subject: Reply with quote
All coolant Question Or 50/50 Question
ZZR-Souls
PostPosted: 13:38 - 30 Mar 2006    Post subject: Reply with quote
Whatever it says on the container.
i.e. Read the instructions and do exactly what it says on the tin.
PostPosted: 13:50 - 30 Mar 2006    Post subject: Reply with quote
Oil in the coolant will cause a horrible scum in the header tank. However hopefully any faults causing that will be fixed with the rebuild (although the water pump seal is a good call).
To clean it out try using some biological washing powder and leaving it to soak overnight.
cokker
PostPosted: 16:02 - 30 Mar 2006    Post subject: Reply with quote
I had a TDR with oil in the coolant, turns out the shop i sent it to do the head gasket put some crappy thin (looked like steel) head gasket in it, they showed me the one going in (copper or something) and never had a problem after that.
No longer have a bike due to a DVLA/Court royal f**k up.
The last post was made 19 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 66.03 Kb
