Honda Bros electrics Problem {my bike hates me}
Carcass
PostPosted: 19:01 - 30 Mar 2006    Post subject: Honda Bros electrics Problem {my bike hates me} Reply with quote
Hi all, So im just coming to the end of finishing my bike thought id start it up to see if the engine runs ok,checked to see that all the wires are in the correct place. As ive turned the key the startor relay has started making a buzzing sound. im not sure what to do
PostPosted: 19:13 - 30 Mar 2006    Post subject: Re: Honda Bros electrics Problem {my bike hates me} Reply with quote
Sounds like it needs a charge.
Either bump start the bike and ride it a bit to get charge back in or charge the battery.
Carcass
PostPosted: 19:31 - 30 Mar 2006    Post subject: Re: Honda Bros electrics Problem {my bike hates me} Reply with quote
well i charged the battery switched it on and pressed the horn to see if there was any power going through which there was , also one of the indicators were on as a solid light rather than blinking and it was the same on the other indicator.
PostPosted: 19:35 - 30 Mar 2006    Post subject: Re: Honda Bros electrics Problem {my bike hates me} Reply with quote
How about the headlights?
How do they look on full beam?
It's still sounding like a deadish battery.
Carcass
PostPosted: 19:39 - 30 Mar 2006    Post subject: Re: Honda Bros electrics Problem {my bike hates me} Reply with quote
i havent got the front light on atm { im building the bike} but i thought it shouldnt be making that noise from just switching the ignition on
Nath
PostPosted: 20:39 - 30 Mar 2006    Post subject: Reply with quote
So you get the buzzing sound from turning on the ignition, rather than from pressing the starter button?
Maybe the relay is stuck on, or the start button on the switchgear could be playing up. Try disconnecting the rhs switchgear, and seeing if the solenoid still buzzes when you turn the key. If it does, try hitting it a bit.
PS. Is your username related to the infamous grindcore band of the late 80s/early 90s?
Hard livin', hard luck.
baldy
PostPosted: 21:02 - 31 Mar 2006    Post subject: Reply with quote
Try changing the connections around on the flasher relay. My c90 did the same.
One day i will rule the world, just not today.
Guest
PostPosted: 23:08 - 31 Mar 2006    Post subject: Reply with quote
Yep, if it's the starter solenoid pulling in without thumbing the button, then either the button is stuck on or you've connected a permanent live to it by mistake.
It's not a petrol pump priming itself is it? Dunno if yours has got one but ....
sickpup
Old Timer
PostPosted: 10:51 - 01 Apr 2006    Post subject: Reply with quote
Probably.
Carcass
PostPosted: 16:10 - 02 Apr 2006    Post subject: Reply with quote
Thanks guys , the battery was toast after all , i hooked up a car battery and sorted out a fuel blockage its now running nicely Very Happy
now i just need to find some speedo clocks
Cheers Carcass
The last post was made 19 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 63.6 Kb
