SQL Query
NSR Mick
PostPosted: 22:37 - 29 Mar 2006    Post subject: SQL Query Reply with quote
I have a table populated with data and one column is year. What I need to do is change all the data in this column to the same value.
Can anyone help with an sql command?
PostPosted: 22:39 - 29 Mar 2006    Post subject: Reply with quote
Think that is going to vary with the flavour of SQL you are using. Generally easy to do though.
NSR Mick
PostPosted: 22:41 - 29 Mar 2006    Post subject: Reply with quote
It's Sybase SQL Anywhere 8 Thumbs Up
Suzuki
Roger
PostPosted: 22:45 - 29 Mar 2006    Post subject: Reply with quote
Code:
UPDATE table_name SET column_name = 'VALUE';
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
NSR Mick
PostPosted: 22:51 - 29 Mar 2006    Post subject: Reply with quote
Suzuki my friend you are my hero, spot on. Thumbs Up
Thanks for the quick response too. Karma
Suzuki
Roger
PostPosted: 22:56 - 29 Mar 2006    Post subject: Reply with quote
I do it for a living Wink
Glad you're sorted.
NSR Mick
PostPosted: 23:09 - 29 Mar 2006    Post subject: Reply with quote
Very Happy
Proper weight off my shoulders that one. It is actually bike related, its for a sprint results program that happens to have the date hard coded into the app, so I'm just going to let the app insert the date as 2005 in each entry and then just change them all to 2006 at the end of the day. Wink
PostPosted: 23:45 - 29 Mar 2006    Post subject: Reply with quote
Not sure on Sybase. With Oracle you can just add days to a date, so you could do:-
update table_name set date_field = date_field + 365
Default is that it adds days.
All the bst
NSR Mick
PostPosted: 21:35 - 30 Mar 2006    Post subject: Reply with quote
Thanks for that Kieth, I do infact have the delphi source code for the app so could change the sql within the app. The only problem being is that i dont have some of the modules required to recompile it. Crying or Very sad
PostPosted: 22:07 - 30 Mar 2006    Post subject: Reply with quote
How complex is the system? What is it all written in? Is it a commercial application?
NSR Mick
PostPosted: 22:21 - 30 Mar 2006    Post subject: Reply with quote
No its not commercial app, it was written by a mate of mine i dont see anymore using Delphi 6. I'm pretty sure he used some 3rd party add on modules as he was a Delphi programmer by trade.
PostPosted: 22:31 - 30 Mar 2006    Post subject: Reply with quote
What does it do? Possible to rewrite it easily?
NSR Mick
PostPosted: 22:37 - 30 Mar 2006    Post subject: Reply with quote
It puts sprint time results into a database and then will create a print out of results, not rocket science but could it be rewritten easily? Not by me thats for sure.
PostPosted: 22:39 - 30 Mar 2006    Post subject: Reply with quote
Sounds like it could be done fairly easily. Does it need to be done on a laptop at a drag strip, or is it for publishing the results online?
NSR Mick
PostPosted: 22:49 - 30 Mar 2006    Post subject: Reply with quote
times are inputed pretty much live, the commentator has a laptop allowing him to view riders previous runs that day, and theres a machine in the paddock so that riders can check how there doing in their class etc, both of these machines view the data via http pages that are generated by the delphi app. the only time the year will be an issue is after all runs are complete and the results printed for the trophy presentation at the end of the day. at no other time is the date in the table seen or used.
PostPosted: 22:56 - 30 Mar 2006    Post subject: Reply with quote
Any more details on the http generation? Is it just a static html document generated every so often, or some kind of dynamic page (eg, php / asp script running on a web server).
NSR Mick
PostPosted: 22:57 - 30 Mar 2006    Post subject: Reply with quote
Its Dynamic, the pages are generated by the delphi app, give me 10 minutes and I'll pm you an address so you can see how it works.
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 97.1 Kb
