First DIY service.
Jack_Cheese
PostPosted: 16:03 - 31 Mar 2006    Post subject: First DIY service. Reply with quote
12,000km is coming up, and my bike has been more neglected than i anticipated. I removed the standard plug to find it black and oily, chunks of insulator missing, sooty deposits and a worn electrode. Oh, and it was the wrong plug.
There's a few things i need to do including the following;
Arrow replace gearbox oil
Arrow replace air filter
Arrow replace fuel filter
Arrow new C&S
Arrow replace brake pads
Arrow check brake fluid + top up if necessary
Is there any practical advice i might need to help me through it? The brake fluid and tranny oil top-ups are worrying me because i have no idea what hydraulic fluid and oil to use.
The C&S has me stumped, too. I've got a paddock stand, so the rear wheel should come out in a jiffy, but how do i split the link on the old chain to get it off? And how do i assemble the new chain?
I'm too much of a chicken to do the fork seals, so it's going in for them. £70 for fitting only sounds steep, though.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
garry
PostPosted: 01:57 - 02 Apr 2006    Post subject: service Reply with quote
look on this site for free online service manuals, basic servicing is easy to do yourself , with the information found for free !!!!!!!!!!
so long so long so long and thanks for all the fish !
PostPosted: 02:14 - 02 Apr 2006    Post subject: Reply with quote
You need to buy a manual.
The type of brake fluid to use should be written on the filler cap. I bet you look at it every time you are on the bike. Wink
Cause and effect?
The C&S has me stumped, too. I've got a paddock stand, so the rear wheel should come out in a jiffy, but how do i split the link on the old chain to get it off? And how do I assemble the new chain?
If it is an endless chain (no split link) you will need either a chain splitting tool, an angle grinder or drop the swingarm out. To put the new one on, either use the split link or you will need the use of a chain rivetting tool to fit the pressd-on link. I personally wouldn't use a split link on anything bigger than a 250cc bike. You can fit it using the split link then take it to a garage to get them to fit the rivet link if you want.
Now go get that manual, download or buy. I recommend buy because it is difficult to put your computer next to the bike for quick reference and you would get the keys all oily.
Muzaffar
PostPosted: 15:50 - 04 Apr 2006    Post subject: Reply with quote
What bike do you have, in case i have the manual
Jack_Cheese
PostPosted: 16:15 - 05 Apr 2006    Post subject: Reply with quote
Cagiva planet 125. I got the brake pads done - the old ones were caked in a brake dust/fork oil mush which rendered my fropnt brakes useless. Cleaned a LOT of grit from around the pistons, too.
I'm also trying to derestrict it, but i have no bloody idea where the main jet it located on my carb!
Jack
Nath
PostPosted: 22:36 - 05 Apr 2006    Post subject: Reply with quote
Poking down into the floatbowl?
Hard livin', hard luck.
Jack_Cheese
PostPosted: 23:27 - 05 Apr 2006    Post subject: Reply with quote
To me the carb looks like a mini fire hydrent with tubes coming in and going out, with the float bowl on the bottom. I'll have a poke round tomorrow and try and locate it. failing that, i'll take bits off untill i find the jet.
Jack
PostPosted: 23:36 - 05 Apr 2006    Post subject: Reply with quote
The main jet is inside the float bowl, you have to take it off to get at it.
Assuming you didn't know this, PLEASE leave it alone until you at a minimum have a workshop manual in front of you. The carb is a precision piece of engineering and should only be messed with if you know what you are trying to achieve by dismantling it.
You could inadvertantly move or damage something you shouldn't then we will get another 'My bike won't start' thread. Like someone a couple of months ago whose 'mate' fiddled with his carb and put the throttle slider back in the wrong way round, then wondered why it redlined as soon as it was started.
Jack_Cheese
PostPosted: 23:52 - 05 Apr 2006    Post subject: Reply with quote
if it's a dell orto carb, should it be roughly the same kind of shape as that on my scooter(also dell orto)? If they look the same shape, i'll guess it's a fair assumption the float bowls look similar. I'll have a look, and if i'm fairly certain i may try and replace the jet. Failing that, i'll have a trip to mmc.
Jack
Muzaffar
PostPosted: 00:44 - 06 Apr 2006    Post subject: Reply with quote
Sorry Jack - i dont have the manual for this.
Hope you get on well with working on it.
Best wishes
Muzafffar Thumbs Up
The last post was made 20 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 67.17 Kb
