| veeeffarr |
 veeeffarr Super Spammer
| map |
 map Mr Calendar
 Posted: 11:56 - 22 Sep 2005 Post subject: |
FWIW I thought the Haynes manual had the service intervals and the work required at each. Somewhere towards the front from what I recall. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| veeeffarr |
 Posted: 14:34 - 08 Mar 2006 Post subject: |
The Haynes for the CG125 is shit though.
Covers 78-2000 with about 2 paragraphs on my model  |
| 8316 |
 8316 Could Be A Chat Bot
 Posted: 14:50 - 08 Mar 2006 Post subject: |
but thats because they are all so similar!
im sure you could do fine even if i lent you my gs125 manual!  ____________________ Now own a Fireblade!! Speed Limits? Bah! |
| fazed |
 fazed Korn is my hero!
 Posted: 15:15 - 08 Mar 2006 Post subject: |
It's not even run in! You could probably change the oil in 20000mile's time and it would still be fine and if you are that cheap you could probably get away with sunflower oil although I do not recommend this  ____________________ gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack. |
| veeeffarr |
| 8316 |
 Posted: 15:25 - 08 Mar 2006 Post subject: |
| fuzz |
 fuzz World Chat Champion
 Posted: 16:24 - 08 Mar 2006 Post subject: |
All modern bikes generally have the same service interval. Minor at 4000, major at 8000. There are differences between models, obviously, but generally speaking, stick with 4k/8k and you shouldn't go too wrong, especially with the CG.
Edit: Took you long enough to reply didn't it, Toby? ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| veeeffarr |
| finpos |
 finpos World Chat Champion
| veeeffarr |
| finpos |
| veeeffarr |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:52 - 01 Apr 2006 Post subject: |
CG125 - change the oil every 1500 miles, clean the air filter at the same time. Check the valve clearances every time they start to get a bit too noisy.
Check, adjust and lubricate the chain every week, check and re-inflate the tyre pressures similarly, or every time the tyres start to feel a bit slippery.
There isn't really much else to it, other than the occasional cleaning out and sanding the shoes in the drum brakes.
Grease the wheel spindles every time you have the wheels off, oil the control cables every month or so, check for rust on the frame and attack it with a wire brush and some Hammerite if you find any, check for tightness of bolts etc every so often. Autosol or similar on the exhaust every time it bothers you is a good idea too. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| jok |
 jok Scooby Slapper
 Posted: 19:08 - 01 Apr 2006 Post subject: |
I've got a slightly different model CG to yours (disc brake on the front), but the service intervals should be similar enough. In the owners hand book it mentions a service at 600m and 2500m, then the next one is 5000m and finally 7500m.
For the 5000m one it recommend that you:
Inspect and clean, adjust, lubricate or replace if necessary:
Fuel Line, Throttle Operation, Valve Clearance, Engine Idle speed,Drive Chain, Brake Fluid, Brake Shoes/Pads, Brake System, Brake Light Switch, Headlight Aim, Clutch System, Suspension, Nuts, Bolts, Fasteners and Wheels/Tyres.
Clean:
Fuel Strainer Screen and Air Cleaner
Replace:
Spark Plug and Engine Oil ____________________ CG125 (stolen->recovered!) || Wars do not decide who's right, only who's left. |
The last post was made 19 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
