Split link and end can gasket
PostPosted: 18:09 - 03 Apr 2006    Post subject: Split link and end can gasket Reply with quote
Hello,
As most of you know, I have recently taken possession of a shiney 1994 RGV250.
Since I got it it has been leaking from the top exhaust end can gasket
https://www.marjay.co.uk/photos/RGV250-3.jpg
It has been dumping a thick black oil residue over the lower end can, and possibly over onto the back tyre. Now, I know that a lot of gaskets can be replaced with Cereal box gaskets... Can I replace an end can gasket with one?
I have some Gun Gum somewhere that I could use to patch it up, will this be as good?
Also, I have noticed today that the bike runs a split-link in the chain. Will I need to get the chain properly rivetted, or is it OK like this on a 55-60bhp two stroke screamer?
Thanks for your help guys! Smile
Mark.
bish777
PostPosted: 18:14 - 03 Apr 2006    Post subject: Reply with quote
Split links are fine, provided the chain is of the correct spec.
I run a split link on my GSXR1100, i run 530 heavy duty.
GSXR1100J
cagiva gezzer
PostPosted: 18:16 - 03 Apr 2006    Post subject: Reply with quote
I'd run a split link as you're going to have the engine out more than you'll be needing to change chains.
As for the gasket it's not going to be more than £2, but card or rubber will do the same job. A smear of silicone sealent will help as the cans won't get that hot.
The last post was made 19 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 36.38 Kb
