How important is track knowledge?
Method
PostPosted: 19:36 - 03 Apr 2006    Post subject: How important is track knowledge? Reply with quote
This came to my head the other day whilst riding home...
Now i havent done a track day ever, but i do ride speedway and grasstrack. Now although these tracks are all ovals... there is a definate advantage to knowing the bumps and lines etc. This doesnt mean however, that a novice can come on with no clue about the track, and stack it straight away because he doesnt know these lines... there gets a point where because of your speed, you need to know the lines etc...
How important is it on a road race? IE. If someone was to do a trackday on a track they've never ridden before, would they find it seriously difficult? Would they be a definate obstruction to others on the course? Or do people regularly turn up without a clue and have no trouble?
Is it important to have a visual idea of where the track goes, lines, etc before trying something like this?
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Davo
Davo To The Rescue!
PostPosted: 19:46 - 03 Apr 2006    Post subject: Reply with quote
Most of the trackday's I've done I've gone in blind with only a rough idea what the circuit looks like (ie its shape).
Generally try and learn as much as possible from the sighting laps as possible.
Bendy
Mrs Sensible
PostPosted: 20:31 - 03 Apr 2006    Post subject: Reply with quote
I generally drop a group on a circuit I don't know, I'll give Inters a go if I'm familiar with the track but book in Novice if I don't.
Obviously knowing the circuit helps but there are always plenty of first timers so I wouldn't say it's a problem.
Silver
PostPosted: 20:52 - 03 Apr 2006    Post subject: Reply with quote
Same here. I'm quite confident at somewhere like Donington (which I've done three times) but somewhere like Cadwell which I've only done once and can be tricky, I'd be a lot less confident of going fast on.
It's an advantage knowing the track, but I would think you should be able to learn a track well enough to go 75% of your best speed within a couple of sessions. Obviously somewhere like Silverstone GP (which is 24 miles long...) will take a bit longer.
Wave2k
G's Stalker
PostPosted: 21:01 - 03 Apr 2006    Post subject: Reply with quote
i ride tracks for fun, the quicker you get you actually find yourself following the lines anyway.
if i was on a track for the first time, id think more about having fun than following lines and being quick.
Ducati 1299 Panigale
2009 Corvette C6 z51
Zimbo
PostPosted: 21:18 - 03 Apr 2006    Post subject: Reply with quote
I try to do a trackday at a circuit before I race, it helps a lot! I generally find it takes a couple of sessions to get to know the circuit a bit, and after that you can set about getting your times down.
Gazdaman
I did a trackday!!!
PostPosted: 01:03 - 04 Apr 2006    Post subject: Reply with quote
I agree with the above, you get to know them as the days go on. The two tracks I've turned up to I've not even known the shape of.
You get a warm up session in the morning aswell. At the Snetterton Hottrax day, anyone in the fast group that hadn't ridden Snetterton before went out with the novices for the warm up laps to get used to it.
Gaz
PostPosted: 01:12 - 04 Apr 2006    Post subject: Reply with quote
On the first session of a trackday you usually get a few sighting laps where you're not allowed to pass, led by an instructor.
These days I stay in fast whatever; will be holding up more people in the first couple of sessions, but still usually manage to get past some as well (apart from at Brands Indy, where I just crash Neutral).
cunni
PostPosted: 10:10 - 06 Apr 2006    Post subject: Reply with quote
Pesonally, I've always studied Racing DVD's and read circuit guides and found out as much as I could before hand, to help me know the lines before I get there. However, studying the lines and taking on board what is said about each corner are two seperate things:
Alot of people talk about this bump here in the braking zone, this crease here at the apex, this bomb hole, that rough patch, negative camber on acceleration down hill there, etc.....
This can all have a massive impact on you subconscious and cause you to limit your speed un-neccessarily at certain circuits!
Best bet is to pick up a vauge idea of the best lines, then forget about it until the day and simply feel your way around. You'll naturally find these bumps and creases, etc and learn how to avoid or handle them. Best way forward me thinks!
TL1000R Parts For Sale!
Barry_M2
PostPosted: 10:35 - 06 Apr 2006    Post subject: Reply with quote
G - You got any plans to visit Brands Indy again this year?
fredsredhat
PostPosted: 00:08 - 07 May 2006    Post subject: Reply with quote
100% agree, a little off topic but an ex racer friend of mine once casually said "this corner,too slippery, no grip, too bumpy blah blah" on the snake pass and now i go round it at about 5mph cos of this mental block he's created.
Dark
PostPosted: 15:38 - 08 May 2006    Post subject: Reply with quote
I'm an avid bike racing fan and pretty much know where all the modern tracks go from watching the races.
I did my first trackday at Cadwell and i already knew which way the corners went and how tight they were. I worked my lines out in the first session and started having fun from the second session onwards.
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
PostPosted: 18:11 - 08 May 2006    Post subject: Reply with quote
Yep, watch out for the Carnage at the end of July Neutral.
The last post was made 20 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 78.9 Kb
