Switches
andrew
Mister Road Rage
PostPosted: 13:15 - 04 Apr 2006    Post subject: Switches Reply with quote
I'm looking to replace the switch gear on my new bike with single switches, the thing is the only switches i can find are not waterproof and won't look any better than having the switch gear on the bike.
Could someone recommend a company that sells such things?
PostPosted: 13:22 - 04 Apr 2006    Post subject: Reply with quote
What sort of switches did you have in mind? What bike are they going on?
try:
https://www.vehiclewiringproducts.co.uk
or
https://www.cpc.co.uk
The only individual switches I can think of designed for motorcycles are the old Lucas style ones you find on classic bikes. They are pish.
andrew
Mister Road Rage
PostPosted: 13:42 - 04 Apr 2006    Post subject: Reply with quote
I'm turning an old firestorm i have into a naked bike and want to get rid of the swicth gear, the plan was to have a push start button where the barrel sits and having a button one side for the kill switch and one for the horn on the other side.
I've seen some old lucas ones on the net but don't think they will go with the look of the bike.
I'm also after a waterproof key switch that i could hide somewhere on the bike to actually enable ignition.
Those 2 sites look great so far though. Cheers.
mr.z
PostPosted: 13:46 - 04 Apr 2006    Post subject: Reply with quote
Splashproof dolly switch
36450
Fitted with black PVC boot which covers lever & spigot. Plastic Lever, metal spigot.
Fits 13mm hole. 10 amp. Ref:36450 £2.96
Been useing these, survived numerous extremely thorough soakings, provided the underside is covered well enough... note they are 10amp so only really usefull for small stuff (phones, gps) or relays..
PostPosted: 18:25 - 04 Apr 2006    Post subject: Reply with quote
A lot of older bikes used to have an ignition flick-switch mounted in the top of the headlamp shell (where you can tuck all the wiring neatly away).
How about an intermittant flick-switch of the type MrZ describes in the top of the headlamp instead of a starter button? That would be cool. Would sure as hell confuse a thief too.
andrew
Mister Road Rage
PostPosted: 18:39 - 04 Apr 2006    Post subject: Reply with quote
The headlights i've ordered are small twin halogen spot things, basically i don't want to be drilling into these at all because it will ruin the look of them. The idea was to have the push button where the barrel sits and a key or flick switch fitted somewhere on the bike that's hard to find. Instead of a steering lock i would always use a disc lock which to me seems safer than a steering lock anyway.
The red push switches they have on that first site you linked to seem like they'll do the job, i just wonder how well they'll cope in the wet and will also have to measure the size of the hole it would sit in. I was hoping to find a really tarty one that said start on it but doubt i'll be able to get my hands on one. Very Happy
JMH
PostPosted: 20:39 - 04 Apr 2006    Post subject: Reply with quote
Do you all have any local custom car shops out that way? Ther are some shops here in the States that have buttons that say "Start" or "Go!" on them. Might want to check Summit Racing Parts for those: https://www.summitracing.com
Also, Dennis Kirk has a good selection of switches (I've bought several from them to replace all the bar switches on my bikes). Some are even made for off-road riding (mud, water, debris, etcetera). Try them out too: https://www.denniskirk.com
Hope this helps!
--JMH
andrew
Mister Road Rage
PostPosted: 21:55 - 04 Apr 2006    Post subject: Reply with quote
Hope this helps!
--JMH
They're both good stores but i can't seem to find any switches with GO written on them, the only switches i could find were similar to the ones on the UK store. Maybe i'm just not looking hard enough. Laughing
The last post was made 20 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 58.89 Kb
