Circuit Problems??
JonB_5
PostPosted: 08:49 - 05 Apr 2006    Post subject: Circuit Problems?? Reply with quote
I have just bought a new battery this weekend and
decided to check the charging circuit!
When the bike is idleing I am getting 14V DC across
the battery terminals. When increasing to 5000rpm the
value decreases to 13.3V. Both of these values are
when the battery is under load with all lights on. The
battery voltage is 13.8V before the bike was started.
I tested the alternator and got 86V AC across each
pair @5000rpm and 70V AC @ idle.
Any ideas guys as to why the voltage drops when the
rpm increases.
Thanks Jon
finpos
PostPosted: 10:33 - 05 Apr 2006    Post subject: Reply with quote
Possibly just the regulator kicking in as the output from the generator increases. Unless you have a problem, I'd not worry too much.
Apart form having a 13.8V battery. Now, that's odd.
finpos.
Nath
PostPosted: 10:39 - 05 Apr 2006    Post subject: Reply with quote
My bike does the same... Just assumed it was normal.
Hard livin', hard luck.
Guest
PostPosted: 10:41 - 05 Apr 2006    Post subject: Reply with quote
if it's still charging even with the lights on I wouldn't worry
meooo
PostPosted: 00:39 - 07 Apr 2006    Post subject: Reply with quote
if the battery was flat, the charge rate would be higher.
Voltage for a fully charged battery would be 12/14volts, with full load on, the alternator will cover that & still add charge to the battery, so as above, the regulator is adjusting charge to suit.
The last post was made 20 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 42.16 Kb
