| killa |
 killa Won't Shut Up
 Posted: 10:03 - 05 Apr 2006 Post subject: VFR being a complete twat! |
Right so using the old term, suck, squeeze, bang, blow, between me and the mechanic we have been trying to establish why the VFR isn’t starting.
Before the bike stopped I was getting back firing, poor throttle response, spluttering, so I suspected gummed up carbs from being stood for so long before and also using the Haines for problem solving it lead me to believe they were causing the problem.
The carbs weren’t the problem in the end but thankfully found something that might have been causing the fuel problem when putting the thing back together, the air line that works the diaphragm had a huge gash on the under side, so I changed it.
The bike turned over but didn’t fire, I’ve got spark, the coils are fine to cut a long story short he was checking over it and came to the conclusion the starter motor might be on its last legs.
When you have full charge in the battery (which I have to add isn’t that old) the engine turns over quite quickly at first but seems to die down very quickly, too quickly in fact, we checked the battery when starting and it was giving what it needed to fire.
Does this seem like a correct diagnostic to you guys?
Any advice appreciated.
Killa ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| finpos |
 finpos World Chat Champion
| killa |
 killa Won't Shut Up
| finpos |
| killa |
 killa Won't Shut Up
 Posted: 11:48 - 05 Apr 2006 Post subject: |
If I whack a heavier battery on there then, and the motor sounds like it isn’t giving me the right stuff, do I look into changing it then? ____________________ Cleverly disguised as a responsible adult.
| finpos |
| killa |
 killa Won't Shut Up
 Posted: 13:06 - 05 Apr 2006 Post subject: |
The connections look pretty good, the battery is a possibility.
Is it possible to leave the normal battery on there running the ignition etc, then whack a heavier battery on it to start the bike?
The carbs were cleaned, so obviously stripped, could this cause the engine to not receive what it needs if it has been setup wrong? ____________________ Cleverly disguised as a responsible adult.
| finpos |
 Posted: 13:26 - 05 Apr 2006 Post subject: |
Well, If you've messed around with the carbs, it's always possible that you've disturbed the settings and it's causing you a problem. If you have a manual, it should give you basic settings to get you started. Of course, you could have re-assembled them wrongly, but that's a can of worms for another day.
But before you go down that road - the golden rule of trying to start a truculant bike is always, always make sure the battery is 100% effective first. Otherwise you'll spend your time chasing all kinds of ghosts around (e.g. thinking your starter motor is knackered )
Sure, you can leave the suspect battery in the circuit. It'll be just the same as trying to jump-start a bike with a flat battery. But I always disconnect it myself, because the second you connect your good battery into a circuit with a bad battery, the bad one will start sucking power from the good one - power that you want to turn your starter motor and run the ignition with. So, if in doubt, take it out. It's a 10 second job to disconnect the earth lead from the bikes battery.
finpos. |
| ZZR-Souls |
 ZZR-Souls Renault 5 Driver
 Posted: 14:52 - 05 Apr 2006 Post subject: |
Check the diaphragm in the fuel tap. If that has a hole in it you wont be getting any fuel through to the carbs. I know you've changed the vacuum pipe, but what about the diaphragm??
This would also give you the backfire and poor power output you've been experiencing. ____________________ JOIN IN THE BIGGEST RIDE-OUT OF 2007 here |
| Vin |
 Vin World Chat Champion
| finpos |
| killa |
 killa Won't Shut Up
 Posted: 17:03 - 05 Apr 2006 Post subject: |
I've tried all the above, diaphragm is good, filter in tank is good also.
The carbs are getting fuel i took the pipe off after trying to start it and fuel gushed out....
Petrol on lips burns man!  ____________________ Cleverly disguised as a responsible adult.
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
| craigs23 |
 craigs23 Mr Muscle
 Posted: 18:37 - 05 Apr 2006 Post subject: |
https://akhara.com/nc30/fueltapmod/index.html
Did you get a good reading when revving the bike with the voltmeter across the terminals? Sounds like a dodgy rec. ruining a battery to me  |
The last post was made 20 years, 179 days ago. Instead of replying here, would creating a new thread be more useful? |
