Slipping clutch @ high revs
shammon
PostPosted: 19:14 - 04 Apr 2006    Post subject: Slipping clutch @ high revs Reply with quote
Out today in my Yamaha xj600 and rides well , but it started to clutch slip in gear when giving it some very hard throttle,( in high gears) i suspect the clutch is needing replaced, other than that it rides fine, inc from start off in 1st gear? Any advice what this is other than a new clutch required soon.. Rolling Eyes
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
tatters
Exxon Valdez
PostPosted: 19:27 - 04 Apr 2006    Post subject: Reply with quote
make sure theres some play in the clutch cable (should,nt be tight)
other wise change the friction plates in the clutch.
shammon
PostPosted: 19:34 - 04 Apr 2006    Post subject: Reply with quote
Could be play.. i tightened the clutch lever to be very responsive...il try letting some play in it il try that later thanks.
Gazdaman
I did a trackday!!!
PostPosted: 21:17 - 04 Apr 2006    Post subject: Reply with quote
Mine did that. Never got around to changing the plates though. Bought them, just never did it.
Try adjusting it first, other than that, just get some new friction plates and springs. Should set you back less than £50.
Mine didn't slip when it was 33bhp, but couldn't handle the full power. It would lift the front wheel off the power if you really gave it some off the line though.
Gaz
shammon
PostPosted: 13:26 - 05 Apr 2006    Post subject: Reply with quote
Left about 10mm play and sorted Thumbs Up
JeffT
PostPosted: 16:57 - 05 Apr 2006    Post subject: Reply with quote
I have been suffering this on my Divvy too, and coincidently have recently adjusted the clutch.
Will be checking it has appropriate slack when i get home!
Gazdaman
I did a trackday!!!
PostPosted: 18:40 - 05 Apr 2006    Post subject: Reply with quote
10mm is a bit much, about half that is good.
Gaz
Visitor Q
$25 whore
PostPosted: 15:50 - 06 Apr 2006    Post subject: Reply with quote
Well my cbr 6 started slipping a tiny bit in the higher gears.
Then it slipped a bit more.
Then it went completely at 140. Luckily i was on the motorway, and near my gaff, so i pushed it home (the heavy sod).
My advice, replace it.
As said, its 40 quid in parts, plus maybe a tenner for extra tools.
You will need the daddy of a socket head to do the central clutch nut. I think i went out and bought an impact wrench one or something stupidly ott like that.
And you have to wedge the back well with some wood.
Dont forget to buy a new central clutch nut as it might very well be a staked one.
PostPosted: 15:58 - 06 Apr 2006    Post subject: Reply with quote
Divvy clutch is a doddle to change the plates in. No need for a large socket either. Take the clutch arm out of the cover, take the cover off ad then just 6 (think) bolts with 10mm heads to remove to get the pressure plate off and then the plates out.
With the bike on the side stand you don't have to drain the oil either.
Visitor Q
$25 whore
PostPosted: 16:00 - 06 Apr 2006    Post subject: Reply with quote
I feel swindled.
The last post was made 20 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 66.59 Kb
