Fork assembly problem :(
loply
PostPosted: 19:12 - 08 Apr 2006    Post subject: Fork assembly problem :( Reply with quote
Hi folks,
I took one of my USD forks from my Yamaha SZR660 (same forks as the TZRs) apart today to change the fork seal. Ive done this job once before.
When I go to reassemble the fork, when I bash the gold ring with the teflon inner coating into the fork tube, the slider gets stuck.
As soon as you bash the gold thing half way in or more, the slider gets totally stuck solid and is a bastard to remove again.
Any idea what this could be? Its driving me insane, I hope I dont need new forks.
Ill post a pic tomorrow.
Rich
Yamaha SZR660 Caution to the wind, the throttle pinned!
zenodamper
PostPosted: 23:07 - 08 Apr 2006    Post subject: Reply with quote
...this gold bit with inner teflon coating would be the guide bushing, right? If it is getting stuck, you will most likely be needing a new one, and some dressing on the seat... Maybe getting a set of fork seal drivers would be a better way to put the stuff back in... save more future problems from happening. Wink
loply
PostPosted: 17:42 - 09 Apr 2006    Post subject: Reply with quote
The guide bushing yeah, its not getting stuck itself - The bushing goes in fairly easily, but once its in, the fork wont slide...
zenodamper
PostPosted: 23:22 - 09 Apr 2006    Post subject: Reply with quote
Ya, and on the flip side of your problem, is the bushing that goes in easily enough; but the fork gains another kind of problem - in other words, the tolerance/clearance is quite important... so, take a good look at which bit has the problem, the bushing or its seat, and more than likely you will need to change that bushing. Razz
loply
PostPosted: 00:15 - 11 Apr 2006    Post subject: Reply with quote
How much does a guide bushing cost normally?
zenodamper
PostPosted: 01:15 - 11 Apr 2006    Post subject: Reply with quote
That is an excellent question; but alas, I have not been back in the UK long enough to have had to purchase any... I would imagine, by converting from AUD, around a tenner...
loply
PostPosted: 18:40 - 11 Apr 2006    Post subject: Reply with quote
Replacement guide bush is around £20, but the guy at the parts shop reckoned a worn guide bush would cause free play in the stanchion, rather than causing it to jam...
I kind of agree with that theory; Why would a worn bush cause it to jam?
Then again, what else could it be?
I don't have £20 to waste if it's not the bush, but I can't explain it really... Any other thoughts at all?
zenodamper
PostPosted: 19:07 - 11 Apr 2006    Post subject: Reply with quote
There is the worn bushing scenario, and there is the 'been banged in lots of times' bushing situation whereby the edges get a little warped, and end up pinching on the fork staunchion... Or even, the seat/ledge area of the outer tube could have gotten nicked or damged, which in turn will also squeeze inwards... It is very difficult to know without feeling it for myself, as there could be other reasons as to why things are not as slidey as they should be...
cagiva gezzer
PostPosted: 19:28 - 11 Apr 2006    Post subject: Reply with quote
Did you keep all the parts from each leg together? i.e. , have you swapped parts from the left leg to the right? Upper and lower bushes?
loply
PostPosted: 19:47 - 11 Apr 2006    Post subject: Reply with quote
No, I only took one fork apart, and put the same parts back in. Ive only put two parts in (upper bush and lower bush), so theres no question of things being in the wrong order...
Its ridiculous - It slid before, so why doesnt it slide now?
Nath
PostPosted: 19:53 - 11 Apr 2006    Post subject: Reply with quote
I know it's obvious, but are you sure you're bashing it in square?
Hard livin', hard luck.
cagiva gezzer
PostPosted: 20:24 - 11 Apr 2006    Post subject: Reply with quote
You've done it before, it worked.
You've got the manual.
a few energetic blows
My only thoughts are that the bushes are mixed up or they are damaged.
loply
PostPosted: 17:51 - 12 Apr 2006    Post subject: Reply with quote
I bash it in evenly until it fills its seat, so it must be square.
Im going to remove the bush later this evening and closely examine it for damage, twisting etc.
The last post was made 19 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 74.91 Kb
