Processors 101
WildGoose
White Van Man
PostPosted: 23:32 - 10 Apr 2006    Post subject: Processors 101 Reply with quote
right, recent quest to try and understand a bit more about modern hardware, with a view to building my own pc...eventually
been scouring the net, but finding it hard to find info that doesnt already assume at the very least that you are a competent geekist
so i would like anyone willing to spell some things out for me in black and white idiot language
been looking at intel site
now why they cant provide the simple differences in simple language i dont know, but its hard to decipher all the crap
they list the following under desktop:-
Intel® Core™ Duo Processor
Intel® Pentium® Processor Extreme Edition
Intel® Pentium® D Processor
Intel® Pentium® 4 Processor Extreme Edition supporting Hyper-Threading Technology
Intel® Pentium® 4 Processor supporting Hyper-threading Technology
what exactly is the extreme edition, as ebuyer doesnt seem to say fuck all about anything extreme edition, and the processor numbers corresponding to the extreme editions seem hard to find to buy, are they out yet?
whats the "pentium processor extreme edition" without the pentium 4 moniker all about?
basically what are the differences between all the above, and what do you need for your basic, but reasonable sharp end desktop pc at home for playing games
i want a high end system, but if you just pick the product that boasts the highest numbers, same for mobo, and ram, then you can spend thousands, and 60% of it would probly go unused...
im finding it hard to find the balance, particularly someone like me who is drawn to buying the thing with the highest numbers
if you havent got time, then please dont send me to google
but if you fancy clearing some things up for me (and im sure others) then it would be greatly appreciated, share the wealth of knowledge here
havent quite got round to AMD yet, apart from the fact they seem to be slightly cheaper, and the numbers dont match processor speeds annoyingly
many thanks Karma
senna_f4
PostPosted: 23:49 - 10 Apr 2006    Post subject: Reply with quote
Agree with Siggi Thumbs Up
What will you use your pc for?
To avoid all the problems of incompatabilites I suggest looking at bundles from a reputable place such as this;
https://www.overclockers.co.uk/acatalog/Bundles.html
Buy it there or go elsewhere and get the components, at least you know they will all work together, all sockets and stuff.
"You don't know the power of the dark side."
DucatiEVO
PostPosted: 23:59 - 10 Apr 2006    Post subject: Reply with quote
Extreme Edition is a normal P4 with a massive 2Mb on-die cache (full speed).
You get a performance boost but it's no way worth the huge bump in price...
Better to go AMD Dual-Core! Thumbs Up
aKa: Ducky
fuzz
PostPosted: 00:04 - 11 Apr 2006    Post subject: Reply with quote
For a rundown on specs of each processor, try here:
https://processorfinder.intel.com/scripts/default.asp
Pentium Ds have up to a whopping 4MB L2 cache (so expect high price) but only go to 3.4GHz so far. The top-of-the-range P4 Extreme Edition run on a 1066MHz bus, so you need a motherboard that supports it. The Pentium Extreme Edition is a cross between P4 Extreme and Pentium D.
daz|n00by
The Internet
PostPosted: 00:14 - 11 Apr 2006    Post subject: Reply with quote
which means fuck-all until the OS and apps are also 64-bit, which they're not yet)
Would you like a windows xp 64 OS and yes its a full working version?
Or maybe a ful working version of vista with drivers?
i have been instaling xp 64 bit for a while now m8 and i have to say it does appear to be faster(but thats on a clean system with top of the range inards)
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
fuzz
PostPosted: 00:32 - 11 Apr 2006    Post subject: Re: Processors 101 Reply with quote
The trouble with Intel, is they use the same name for processors with different architecture. For example, with the P4 Extreme, some use 800MHz bus, some use 1066MHZ bus. Some support 64-bit, other don't. Some you can use with your old Springdale chipset, others require a socket 775 motherboard, yet they are all branded as P4 Extreme Edition.
The main difference between Extreme and P4 Extreme is that the Extreme uses dual core technology and hyperthreading, whereas the P4 Extreme uses only hyperthreading. The Pentium D uses dual core.
Dual core is like hyperthreading, in that it allows the CPU to process more than one command at a time. It is more efficient though, because it is like two processors working on different threads rather than the same processor working on two threads at the same time. A dual core with hyperthreading can therefore process four threads at a time.
WildGoose
White Van Man
PostPosted: 00:39 - 11 Apr 2006    Post subject: Reply with quote
wow, hell of a lot to take in, but thanks for all the replies
its mainly looking to be a gaming pc, so am i better looking towards the AMD side of things?
daz|n00by
The Internet
PostPosted: 01:24 - 11 Apr 2006    Post subject: Reply with quote
I would say a lot of its down to cost and choice but as a general rule i would say AMD for gamers and fast response and Pentium for reliability and stability.
Since i changed over to using p4's i have never ever had a pc crash and very rarely format now either.
But i do notice that little kind of speed edge missing that the AMD used to give and have to have a go on the missus and sons every now and then just to remind me of what i,m missing.
sickpup
Old Timer
PostPosted: 01:46 - 11 Apr 2006    Post subject: Reply with quote
Yes please.
daz|n00by
The Internet
PostPosted: 01:48 - 11 Apr 2006    Post subject: Reply with quote
sickpup wrote:
Yes please.
Throw me a pm tomorrow m8 and i,ll put it up on the ftp for you when i get in from work .
veeeffarr
PostPosted: 10:58 - 11 Apr 2006    Post subject: Reply with quote
Do you mean the public beta? As I'm pretty sure Vista isn't finished yet.
Psychofly
PostPosted: 11:52 - 11 Apr 2006    Post subject: Reply with quote
Anyone tried the XP 64-bit running NVIDIA gfx card and playing games like Counterstrike Source and Battlefield 2 ?
sickpup
Old Timer
PostPosted: 13:20 - 11 Apr 2006    Post subject: Reply with quote
Siggi wrote:
I've not heard good things about their stability. The XP-64 is very beta.
Not any longer. I got 10 non-transferable NFD lcense copies last october. The real problem is lack of driver support.
veeeffarr
PostPosted: 13:29 - 11 Apr 2006    Post subject: Reply with quote
Physics cards are where it's at
veeeffarr
PostPosted: 13:31 - 11 Apr 2006    Post subject: Reply with quote
Fuck me...
Tarmacsurfer
PostPosted: 13:45 - 11 Apr 2006    Post subject: Reply with quote
Can't say anything about Intel reliability, but AMD is far from bad. My current fileserver is an old XP2000+, current uptime ~8 months. Only reason it's been offline in the last 2 years was a power outage.
My main desktop is a very OCd Venice 3000, uptime ~5 or 6 weeks now. Simply doesn't need rebooting. Both machines running XP pro (the XP2000+ was running Win2kAS for a while, that was also impressively solid, changed to XP for easier access to virus protection). A business friend used to prate on about the merits of Intel, but afraid I just don't see it these days.
I'm immortal. Well, so far.
WildGoose
White Van Man
PostPosted: 14:02 - 11 Apr 2006    Post subject: Reply with quote
right, bit rash perhaps, but i've bought the board and cpu
Athlon 64 3700 San Diego
and A8N32-SLI Deluxe motherboard
opinions?
and any suggestions for other components like, PSU, Hard drives and cases?
fuzz
PostPosted: 14:22 - 11 Apr 2006    Post subject: Reply with quote
Nothing less than a 400W power supply, depending on amount of hard and optical drives you have and type of graphics card.
For hard drives, Maxtor have always done me well - I still have a working 400MB drive form my first 486. Seagate are also good, but stay away from Fujitsu.
The you need to decide whether you want IDE or SATA. SATA is faster but more expensive. I'd stick with IDE unles you are building a RAID array, although with the motherboard you have chosen, a SATA drive will most likely perform slightly better. A 200GB drive will cost about £50 and should last you well.
https://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=89515
For SATA: https://www.ebuyer.com/customer/products/index.html?rb=18103329554&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=102293
Not much in price difference though.
WildGoose
White Van Man
PostPosted: 14:53 - 11 Apr 2006    Post subject: Reply with quote
what are IDE and SATA in idiot language?
and a RAID array?
cheers Thumbs Up
veeeffarr
PostPosted: 15:10 - 11 Apr 2006    Post subject: Reply with quote
and a RAID array?
cheers Thumbs Up
IDE is basically the most common interface used for connecting a hard drive to a computer, can also be used for CDROMs. IDE drives use the ATA standard of connectivity. (ATA is basically where the controller is on the disk drive itself, Advanced Technology Attachment)
SATA is a technology created basically using a serial cable instead of an IDE cable to get a faster data transfer rate, also has the advantage or taking up less space than IDE due to thinner cables
RAID is basically a method of protecting your data incase a hard drive fails (Any more than this and I'll have to type about 20,000 words Razz)
So IDE is an ATA connection with an IDE cable, Serial ATA is an ATA connection done with a serial cable.
WildGoose
White Van Man
PostPosted: 16:30 - 11 Apr 2006    Post subject: Reply with quote
right, been reading up
read something about complications about installing an OS on SATA hard drives bigger than 120gb, you need extra drivers or software or something
anyone shed any light on this?
veeeffarr
PostPosted: 16:34 - 11 Apr 2006    Post subject: Reply with quote
You need to manually load the SATA drivers, just press F6 while loading XP.
Tarmacsurfer
PostPosted: 17:27 - 11 Apr 2006    Post subject: Reply with quote
Currently using 2 Hitachi 7K80 drives in raid0. Whilst they're listed on Ebuyer as SATA1 all of the information (THIS for example) I've found refers to them being SATA2, suffice to say for £65 odd for 160 gig of fast HD seems pretty good to me. Sadly I cant find the Toms Hardware review that initially decided me, but a pair of SATA2 drives in this config is supposedly pretty damn quick (in fact HERE is another site, see the figures for yourself).
Different RAID configs do different things, RAID 0 means 2 80 gig drives become 1 160 gig drive, but as the data is striped across both it works rather fast (and if one drive dies, you've lost it all). RAID 1 is a "safety" configuration, 2 80 gig drives make 1 80 gig drive, everything on one drive is on the other, hence if one fails all your files are still there. There are many more, but none that are too common in the home PC. Just google it for a complete breakdown.
cagiva gezzer
PostPosted: 17:48 - 11 Apr 2006    Post subject: Reply with quote
As said, just load the drivers from a floppy right at the start. Need a working pc to copy the drivers from a cd to start with though..... Confused
Running hardwear based RAID 0, well it's not a "true" RAID, with twin maxtor 80Gb's. Worth it for the speed increase. Think i got a 40% improvement on disk acess times. No data back up, but i've only got music and phots that are all on dvd's anyway.
The last post was made 20 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 128.5 Kb
