| Rookie |
 Rookie World Chat Champion
 Posted: 13:21 - 12 Apr 2006 Post subject: Throttle cable |
So the 'Cat has had all necessary work done to it, I spent a few hours riding it round this morning. It was a proper hoot.
The only thing left doing is the throttle and grips. Basically there are no grips on it because the previous ones were a present for ThunderSteve, and they were heated. Fair enough! However the problem is that the throttle cable has gotten seized, and I only get a very small amount of movement. This means I have virtually no power. It's good since I'm just starting out on a very powerful machine, but I can't go above 60mph.
Also, when it's in neutral, it idles at about 3k, which I assume is too high, and it doesn't stay there. It just revs up all the way to the redline, though I haven't let it get there yet. I've been solving this when riding by keeping it in first and on the biting point when stopped, but it probably isn't doing any favours to the clutch.
Is this all due to the seized throttle cable? And does anyone know how much it will cost to replace, and how tricky it is to fit?
Much obliged.  |
| mr.z |
 mr.z World Chat Champion
 Posted: 14:09 - 12 Apr 2006 Post subject: |
Could also be todo with the throttle return cable if it has one?
Probably one of them stuck under the tank or against the frame..
Not difficult to fit them tbh, idleing is set by a turney nob on the bottom of the carb i''d imagine
Throttle cables (well any of them) are expensive, £20 wouldn't supprise me... i'd reccomend giveing the inner a big load of copper slip, even better is controll cable lubericant, or graphite spray  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| veeeffarr |
 veeeffarr Super Spammer
| Rookie |
 Posted: 14:41 - 12 Apr 2006 Post subject: |
It seems to be freeing up to some degree, I can get to 80mph now.
It does have a return cable I think, Mr.Z, it's a set of 2 cables.
Now I'll leave this one be and go write about the other problem I'm having!  |
| Davo |
 Davo Davo To The Rescue!
 Posted: 15:03 - 12 Apr 2006 Post subject: |
I'd be tempted to whip the tank off, check the cable path & around the carbs. (make sure nothing obstructing the throttle & all carbs are sealed ok).
My R6 had a similar problem, turns out a bit of gravel (from my crash at Brands Hatch got lodged under the throttle rail, and jammed the throttle 1/2 open.
If you want a hand, give us a shout. |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Davo |
The last post was made 19 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
