Help!!!! Brake Problem!!!!!!
sagiliam
PostPosted: 08:24 - 12 Apr 2006    Post subject: Help!!!! Brake Problem!!!!!! Reply with quote
Hello,
Recently my braking has gradually got worse and this morning i noticed that although my lever is springing back into place, the spring and cable at the wheel are sticking and so jamming on my front brake. im not sure if this is the cable, pads or spring? My bike is a suzuki fr50. Any suggestions on what i can do?
Cheers Liam
finpos
PostPosted: 09:10 - 12 Apr 2006    Post subject: Reply with quote
There's two possibilities -
Either the mechanism that operates the brakes is partially seized, and you will need to remove the wheel, dismantle it all, cleaned it up and put back together. Not a big problem.
However, the other possibility is that the brake is doing something called over-camming. This is dangerous, as in it could cause your front wheel to lock up solid when you brake. You really don't want that. It will happen if your brakes are worn and over-adjusted to compensate for the fact.
If in doubt about, don't ride it.
finpos.
Richy
PostPosted: 13:36 - 12 Apr 2006    Post subject: Reply with quote
is there any water contamination in the brake fluid cos this can boil under normal brake use and expand, putting the brakes on all teh time (if it gets really hot it can lock, depends on the amount of water in there). If this is a possibility, drain and refil the brake (prob worth serviceing the caliper at the same time)
garry
PostPosted: 22:43 - 12 Apr 2006    Post subject: brakes Reply with quote
jus hold on a second here !!!!!!!!!!!!
are we talking drum or disc ? i seem a lil confused by answers Confused
so long so long so long and thanks for all the fish !
garry
PostPosted: 22:49 - 12 Apr 2006    Post subject: brakes Reply with quote
just read original question again, and agree with finposas he said............
However, the other possibility is that the brake is doing something called over-camming..........
if your not sure what yer doing , dont feck with brakes mate !!
get it into the shop..
Guest
PostPosted: 23:19 - 12 Apr 2006    Post subject: Reply with quote
Does it look like this?
https://www.suzukicycles.org/photos/FR/FR50/1978_FR50_red_Aus_250.jpg
As said, it sounds like it's over-camming. This wants looking at now as it could be a serious safety issue. It's usually caused by the material wearing off the brake shoes so they can move too far inside the drum.
Drop the front wheel out and pull the brake plate out of the wheel. the cable operates the cam which forces one edge of each brake shoe apart ....
https://img.photobucket.com/albums/v471/fastfitter/frontbrakeshoeside.jpg
Pull the shoes apart against the springs and then 'peel' them off. Fit new (about a tenner I'd guess) and clean and lightly grease the cam spindle where it goes through the brake plate
Richy
PostPosted: 23:40 - 12 Apr 2006    Post subject: Reply with quote
D'OH assumed disc sorry Embarassed
sagiliam
PostPosted: 09:27 - 13 Apr 2006    Post subject: Reply with quote
Hello, thanks for all the replies been a great help. Im not a paticularly mechanical so would it be best for me to get this done at a shop, or is it fairly easy to do?
finpos
PostPosted: 09:56 - 13 Apr 2006    Post subject: Reply with quote
Very few bikes still about with cable operated disks Wink
Liam, if you are not confident, get it to a shop. Bearing in mind my warning about over-camming.
The other thing you can do is get a manual. It will describe the process of dismantling/re-assembling the brakes, which is what you will need to do in case of either of the failures described above. Then you can decide if you fancy tackling the problem - and whether you have the right tools.
The other thing the manual will tell you is how to visually inspect the brakes to tell you if they are overadjusted. I'm afraid I can't help with this on your particular bike.
finpos.
Richy
PostPosted: 12:10 - 13 Apr 2006    Post subject: Reply with quote
damn i really got to read it more carefully
The last post was made 19 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 63.59 Kb
