| Raffles_Gentleman Thug |
 Raffles_Gentleman Thug Trackday Trickster
| Bezzer |
 Bezzer World Chat Champion
| sickpup |
 sickpup Old Timer
| Bezzer |
 Posted: 21:33 - 12 Apr 2006 Post subject: |
It's under load you get the fault proper which is why I mentioned the breather, if it is partially blocked then you get a vacuum in the tank and it cuts the fuel flow down, it might cope when you're revving the bollocks off it at a standstill but under load you want more fuel and it can't give it.
Looking in the tank to see if you have petrol is not checking the breather I meant leaving the tank cap open and going over 7,000rpm on the road, having the cap open prevents a vacuum forming, if it runs OK then the breather is the problem, if it's the same then move onto the fuel filter.
BTW run the tank down a bit before running with the cap open  ____________________ I used to be indecisive but now I'm not quite so sure. |
| Kickstart |
 Kickstart The Oracle
 Posted: 21:50 - 12 Apr 2006 Post subject: |
Could be the breather, but to be honest doubt it. Whenever I have had that problem it has not caused problems at particular revs, nor caused the bike to cut out suddenly. More just feels like the bike is going onto reserve.
Cutting out suddenly suggests electrics to me, although with an injected engine that covers the fueling as well.
If it was the regulator / rectifier then it would stop it starting on the electrics starter long before if would cause running problems.
The last post was made 19 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
