throttle probs
jcolley1364
PostPosted: 11:18 - 13 Apr 2006    Post subject: throttle probs Reply with quote
hi i have a little problem with my ts100 if i rev it and then let go of the throttle it takes a while for the revs to drop back down to normal its a bit annoying when changing gear as the bike is still reving between gears
also not sure if its conected to this problem but when riding it seems like the revs wont go as high as wot they used to any help in solving these problems will be good thanks in advance john
Cillit-BANG
PostPosted: 11:42 - 13 Apr 2006    Post subject: Reply with quote
Check the throttle cable isn't frayed. If it isn't then try flushing it out with wd40 and then dribling a little light oil in there.
It sounds like the cable is dirty and isn't moving as freely as it should.
jcolley1364
PostPosted: 13:44 - 13 Apr 2006    Post subject: Reply with quote
ok cheers i will give that a try tommorrow and let you know how i get on cheers john
fish
PostPosted: 21:00 - 13 Apr 2006    Post subject: Reply with quote
have u tried duck tape.if that doesnt work,try hypercloride...hope this will help.
jcolley1364
PostPosted: 10:17 - 14 Apr 2006    Post subject: Reply with quote
cheers fish by the way hows the petrol tank is it still peeing out fuel
brooky
PostPosted: 17:15 - 14 Apr 2006    Post subject: Reply with quote
If I were you I wouldn't use WD40 on it as it will break down the inner coating of the inside of the cable and eventually the cable will go rusty and stick / snap.
Hope this helps
Suzuki GSX-R 750 K6.
jcolley1364
PostPosted: 17:23 - 14 Apr 2006    Post subject: Reply with quote
what would you say is best thing to use instead of wd40 thanks john
element
PostPosted: 17:47 - 14 Apr 2006    Post subject: Reply with quote
wd dries out after a while. its not a lube. 3in1 oil would be better..
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
jcolley1364
PostPosted: 20:58 - 14 Apr 2006    Post subject: Reply with quote
ok cheers
The last post was made 19 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 58.46 Kb
