screen change
Whizzy
PostPosted: 16:33 - 14 Apr 2006    Post subject: screen change Reply with quote
Anyone help me change a screen on nsr125r plzzzzzz Smile.
I need to know the tools reqd and best way to do it ,many thanks all Wink
Bendy
Mrs Sensible
PostPosted: 17:40 - 14 Apr 2006    Post subject: Reply with quote
Unscrew the current screen.
Screw in the new one.
Look at the bolts holding your current one on, will either be a screwdriver job or an allen key job.
alains
PostPosted: 17:56 - 14 Apr 2006    Post subject: Reply with quote
no! they are fixed by special rivets with a special washer . i've changed mine recently and i use (i dont know the name in english) rivets which you tighten it with special pliers . just do like this :
- cut some washers in thin rubber (about 10mm diameter)
- buy some washers at the diameter of the rivets (medium width)
- put the rivet in the hole , the rubber washer behind then the steel washer and press with the tool
the other is to use round head screws diameter 4mm thread 70 (4 diameter nuts) and do as with the rivets
True Blue
PostPosted: 18:20 - 14 Apr 2006    Post subject: Reply with quote
Get a flathead screw driver and prise off the washers on the inside of your screen. Take out the rivets and throw them as far as you can over you garden fence. You don't want to be putting them back in, it's an arse. Go buy some screen bolts, much easier. Thumbs Up
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
alains
PostPosted: 18:36 - 14 Apr 2006    Post subject: Reply with quote
the problem with these rivets & washers is that they wont work a second . once taken off put them in the bin
True Blue
PostPosted: 18:40 - 14 Apr 2006    Post subject: Reply with quote
They will work a second time as long as you're carefull taking them off. I used them agin when i took the screen off my NSR. They are tricky to get back on though, particularly the ones right down besides the clocks. Mad
alains
PostPosted: 18:46 - 14 Apr 2006    Post subject: Reply with quote
you're right if they are not rusty ! which is not very often the case Sad
jonnay
PostPosted: 19:50 - 14 Apr 2006    Post subject: Reply with quote
Take the old ones out with a screwdriver (prise them off), chuck em in the bin, and then buy some screen bolts Thumbs Up
Come with the bolts (allen key head), washers and a nut for the back.
Jon
::'04 Yamaha Jog:: || ::'01 Honda NSR:: || ::'00 Suzuki Swift:: || ::'89 Swift GTi:: || ::'96 Swift Poverty Spec:: || ::'92 Swift GTi::
The last post was made 19 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 56.97 Kb
