PEG VIBRATION!!!!!!
cookie
PostPosted: 20:03 - 14 Apr 2006    Post subject: PEG VIBRATION!!!!!! Reply with quote
hi
I ride a cbr600f 94 f-s and passed my test in october and recently have found that im getting peg vibration over 5k revs Confused
Is this normal or is it down to something I have done?
I have recently changed the frontpipes and link pipe.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 20:16 - 14 Apr 2006    Post subject: Reply with quote
I'd check your bolts are tight, especially around the rearset area if you had to remove it to fit the system.
I find I get vibration if cruising around 10k revs; some is normal but it shouldn't be all over the rev range.
<pedantic>Closing tags should be preceded with a forward slash</pedantic>
Razz
Gazdaman
I did a trackday!!!
I'd say Siggi's suggestion is unlikely, but possible.
More likely a nut's worked loose somewhere along the line. Did you take the pegs off to fit the system?
Gaz
cookie
PostPosted: 20:22 - 14 Apr 2006    Post subject: Reply with quote
nah, just removed exhaust completley to change downpipes.
cookie
PostPosted: 20:24 - 14 Apr 2006    Post subject: Reply with quote
gaz,
do you mean a nut on the exhaust or around the rearset??
Gazdaman
I did a trackday!!!
PostPosted: 20:43 - 14 Apr 2006    Post subject: Reply with quote
Around the rearsets. Exhaust shouldn't show a problem, unless they're loose and resonating, which in turn is vibrating something else.
Gaz
sickpup
Old Timer
PostPosted: 21:24 - 14 Apr 2006    Post subject: Reply with quote
Siggi wrote:
I get more vibration from my Blade since fitting race pipes & can, it's to do with the motor revving more freely.
No it's not. It's due to a change in the frequency of vibrating parts probably due to differing wall thicknesses in the pipe part of the system thus changing the harmonic resonant frequencies.
cookie
Do you still have the original rubber topped foot pegs on your bike and the original bar end weights? Have you made any changes?
cookie
PostPosted: 20:03 - 20 Apr 2006    Post subject: Reply with quote
still got original parts on.
sickpup
Old Timer
PostPosted: 20:35 - 20 Apr 2006    Post subject: Reply with quote
No its not. You've changed the front pipes and link pipe so yes the vibration frequency will change.
The last post was made 20 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 57.89 Kb
