| mr.z |
 mr.z World Chat Champion
 Posted: 00:48 - 15 Apr 2006 Post subject: Vacuum pipe question? |
Daft maybe but.. what does the vaccum pipe from the tank to the carb do??
Its connected to the tank, while attempting to balance the carbs (imopssible without the tool ) it was suking air into the carb, every couple of seconds (at random) it would go >PFFFT!< the revs would drop a bit then build up.. put a glove on it and it sort of ran normally...
Just wondering really..
I guess it might pull more fuel through wne its needing it? or open a valve on the tap to allow more through?? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| 0ddball |
 0ddball World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
 Posted: 01:04 - 15 Apr 2006 Post subject: |
The carb causes the vacuum in the pipe which opens the diaphragm in the petrol tap allowing fuel to flow from the tank to the carbs. No vaccuum = no fuel flow that's why you don't have an "Off" position on the fuel tap.
When balancing the carbs you should either use another fuel supply or run it on Prime and block the vacuum line as it can give a false reading.
edit. snap, too slow a typist  ____________________ I used to be indecisive but now I'm not quite so sure. |
| mr.z |
 Posted: 01:12 - 15 Apr 2006 Post subject: |
Thanks guys, makes sense.. mine does have an off :o but that makes sense... the original cx didn't have a vacuum and would have problems flooding if left for a week, this explain why i think...
I set up a very clever arrangment with a fuel hose, funnel and bungee's on the garrage celing worked great...
Thanks for that  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| stinkwheel |
| mr.z |
 Posted: 09:21 - 15 Apr 2006 Post subject: |
Yeh i was carefull about that, it wasn't diectly over it (half a bikes length away, it was only full to the point i could see the fuel and the fire extinguisher was right next to me  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 19 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
