My bike is supposed to be derestricted, but doesnt go fast?
simon1221
PostPosted: 23:10 - 14 Apr 2006    Post subject: My bike is supposed to be derestricted, but doesnt go fast? Reply with quote
This is not one of those 'easy answer posts' so anyway:
Arrow Rebuilt the engine last summer, new piston + rings + rebored barrel
Arrow Ran it in to the best of my knowledge but never got over 8000rpm (redline at 10500rpm)
Arrow Found the fuel level was too low so fixed it again
Arrow Turned the powervalve upside down because it wasnt running smooth (and now it does). This has the YPVS + servo + cables etc
Arrow Mixture settings all standard, new spark plug good spark and fuel.
Arrow When fuel was too low never went over 50mph
Arrow Now it doesnt go over 65mph, and thats only just
I adjusted the 'tang' before, but set it back to recently, so it should not be the fuel again.
Anything else it could be, I am going to try it on super unleaded soon and see if that makes any difference.
The power cuts out at 8000rpm rather than increasing...
Question
sickpup
Old Timer
PostPosted: 23:21 - 14 Apr 2006    Post subject: Reply with quote
Sounds like the PV isn't working.
colin1
Captain Safety
PostPosted: 02:15 - 15 Apr 2006    Post subject: Reply with quote
run the engine in neutral, hold the power valve cable, and when you get the revs high, it should go stiff as it pulls the power valve open.
If it does this then your powervalve is stiff and needs cleaning, if not there is a problem with the servo that pulls the power valve maybe.
Having said this Im not an expert, but its a simple thing to try so worth doing.
PostPosted: 12:08 - 15 Apr 2006    Post subject: Re: My bike is supposed to be derestricted, but doesnt go fa Reply with quote
Not sure what you mean by this? If it upside down then the bike will have stuff all top end power.
Also check you have the cables from the servo to the valve connected the right way round.
Standard and restricted it should manage 70~75 true top speed (so about 80 indicated).
simon1221
PostPosted: 22:24 - 15 Apr 2006    Post subject: Reply with quote
I have a feeling it is this, however before it coughed and spluttered all the way through the rev range, particularily at about 6k.
When I changed it it did run a lot smoother.
Finglonga
PostPosted: 00:01 - 16 Apr 2006    Post subject: Reply with quote
Might be worth checking your throttle cable is adjusted correctly and all clips are in place too, then put the powervalve back as it was. Some sort of fueling issue.
Then get your mixture checked by a professional or you will blow the Fecker up.
Andy Sez....
F.Y.Y.F.F.
distortion
PostPosted: 12:59 - 16 Apr 2006    Post subject: Reply with quote
1) PV needs cleaning
2) Its restricted in the exhaust
Theres my Penny Coin Penny Coin worth
simon1221
PostPosted: 18:33 - 16 Apr 2006    Post subject: Reply with quote
1) PV is clean
2) No it isnt
but thanx anyway Wink
PostPosted: 19:14 - 16 Apr 2006    Post subject: Reply with quote
Some TZRs were meant to have had a restriction in the exhaust, but not all. Seems why some only managed about 85 when the power valve was turned.
The last post was made 19 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 61.82 Kb
