Clutch problems?
mattgt
PostPosted: 12:46 - 17 Apr 2006    Post subject: Clutch problems? Reply with quote
I've been having a wee problem lately, and have run out of ideas. This normally happens in 3rd and 6th gear (only), around 6tho with the throttle opening to accelerate. Instead of the revs powering up, what happens is as if i had the clutch pulled half in - there's still acceleration but the revs go mental. Kinda like a racing start - the revs are up there (i have had to be careful of redlining at this stage) and the bike accelerates. As if i were dipping the clutch or something. But all this happens with a simple opening of the throttle, no clutch involved. Could this be a clutch wiring problem, or something more serious?
BFG
PostPosted: 12:51 - 17 Apr 2006    Post subject: Reply with quote
The Bike is a......? Rolling Eyes
If you have a bike with gears and a wet clutch - Sound like clutch wear. Adjust the cable, if that don't work chances aer it's completely worn. Answer - Replace the worn out clutch. Smile
mattgt
PostPosted: 12:59 - 17 Apr 2006    Post subject: Reply with quote
Apologies - it's an RVF400. Had it since september. This only happens now and then, normally when I'm carrying someone. If it does sound like wear, clutches are pricey to replace, no? Im buggered if it is...
BFG
PostPosted: 13:09 - 17 Apr 2006    Post subject: Reply with quote
Not if you do it yourself. Smile About £50 for plates, springs and cover gasket. But may as well do an oil change while you're at it.
Try adjusting the cable first.
It'll get steadily worse, but it won't cause any damage to anything else in the engine. You can make it last by being gentle on the clutch when pulling away and avoiding opening the throttle sharply when there's a lot of load on the engine, such as pillion or up a hill.
mattgt
PostPosted: 13:58 - 17 Apr 2006    Post subject: Reply with quote
okay. just as i feared. i'll take it easy and see how long it goes! gonna take the bike apart soon anyway, have a little looky round.
cheers
Matt
The last post was made 20 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 43.6 Kb
