What is this a sign of?
Rob W
PostPosted: 19:05 - 17 Apr 2006    Post subject: What is this a sign of? Reply with quote
On my bike (ZXR4) it's always been that every 1000rpm in top was bang on 10mph, so obviously 4000rpm was 40mph.
Just recently I've noticed that it's pulling slightly more revs to get the same speed, as in 40mph is now about 4500-4750rpm. Is this a sign of something wearing on the bike like the valves or whatever, or is it just one of those things? I've only recently noticed it, and just wondered if it could be a warning that something was up. Other than that the bike is riding perfectly.
Cheers.
Barry_M2
PostPosted: 19:11 - 17 Apr 2006    Post subject: Reply with quote
Mean's your in 5th and not 6th! Wink
Probably just an inacurate tacho. Could be a dodgy connection as tacho is electrical.
Wouldn't be engine wear.
PostPosted: 21:53 - 17 Apr 2006    Post subject: Reply with quote
More likely the speedo cable needs oiling or you have fitted a tyre with a different profile which has affected the speedo reading.
Could also be caused by clutch slip but this wouldn't be constant and you should be able to feel it happening.
mr.z
PostPosted: 22:12 - 17 Apr 2006    Post subject: Reply with quote
Yeh if they taco/speedo cables were new when you first compared they do go off by quite a bit..
Could be the air filter is slightly blocked or wet.. could even be the weather has warmed up quite a bit? (colder air is more dense, so you tend to get more power in certain condtions when its cold)
Unbalanced carbs? tappets off? looseing compression on one cylinder? could be soooo many things..
PostPosted: 22:39 - 17 Apr 2006    Post subject: Reply with quote
It shouldn't really be anything to do with the mechanical function of the engine. The gearing is all fixed in terms of when the engine turns over once, it moved the gearbox by a certain amount which turns the gearbox a certain amount. There is no room for slippage/ variation. x rpm = y mph and always will do unless you change the number of teeth on one of the gears.
Even if it was running on one cylinder and spewing oil all over the road with a conrod sticking out through the side of the engine, the revs and speed would match.
The only place there is room for slippage is in the clutch which you would notice. If this isn't the case then either your tacho or speedo is lying to you.
Rob W
PostPosted: 11:12 - 18 Apr 2006    Post subject: Reply with quote
Cheers for all the replies lads, Thumbs Up.
The reason I asked is that when me and my dad were twatting through the lanes at Burnham yesterday I noticed that it was revving slightly more than it used to, and the old girl was basically being thrashed constantly for about half an hour or so, and I didn't like the idea thinking that at any minute my engine was about to explode (it probably wasn't far from it).
Rob W
PostPosted: 11:14 - 18 Apr 2006    Post subject: Reply with quote
Interesting point Stink, seeing as my rear tyre is squared off now and pretty much on the limit. You reckon that could be it?
Thinking
feef
Energiser Bunny
PostPosted: 15:10 - 18 Apr 2006    Post subject: Reply with quote
will mean your tyre now has a smaller radius than it did.. not by much, maybe 2/3 mm, but that will have a small effect on the circumference of the tyre, as will tyre pressures, which can make the effective gearing change...
also bear in mind that the effective gearing ratio provided by the tyre profile will change as you lean the bike, so cranked over will result in a slightly higher ratio/lower gear. One of the reasons that racers often won't go into a corner with it near max revs, cos when they lean over they run out of revs, as the gearing drops and they have to rev higher to maintain speed.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
ZRX61
Victor Meldrew
PostPosted: 15:51 - 18 Apr 2006    Post subject: Reply with quote
LMFAO!!! Loose tappets change the overlall engine gearing?? LOL!!! Rolling Eyes
If you have a toolbox do us all a favour: either have it welded shut or throw it in the nearest lake.
mr.z
PostPosted: 16:05 - 18 Apr 2006    Post subject: Reply with quote
Lick my balls mr grumpy arse, not everyone here is a fully seasoned mechanic, just trying to help Razz
Inretrospect yes that post was arse but hey, live and learn..
The last post was made 20 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 68.71 Kb
