| SimonB |
 SimonB Brolly Dolly
| mr.z |
 mr.z World Chat Champion
 Posted: 17:49 - 17 Apr 2006 Post subject: |
It could be the oil pressure switch is on its way... or it is indeed useing up oil.. the oil light is a presure indicator not level (afaik anyways) so i'd have thought it would have to be quite low to be showing low presseure
Oil might be getting past the piston rings/ somewhere and comeing out the exhaust.. i'd defenately try a compression test, or take it to a garrage and get one done. If it was comeing out the caseing or breather pipe you'd see it, that the only other way out...
Good luck, tbh i'd not be rideing it till i at least knew the cause (do a search here for oil starvation to see why ) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kickstart |
 Kickstart The Oracle
| SimonB |
 SimonB Brolly Dolly
 Posted: 21:13 - 17 Apr 2006 Post subject: |
Well I topped it up before and had to put about 500ml in Which is quite a bit I think.
Is it possible that I've not had the valve clearance checked at its recommend time which I think is 16000 miles and I'm on about 19000 miles at the moment.
Thanks for the help so far. ____________________ Bikes: Honda CBR250RR [sold], Yamaha FZR600 [sold], Honda CBR600RR6 |
| gsxrpeak |
 gsxrpeak Trackday Trickster
 Posted: 22:34 - 17 Apr 2006 Post subject: |
| Kickstart |
 Posted: 22:36 - 17 Apr 2006 Post subject: |
Probably is a bit much, but they do use a load as I said. Valve clearances alone are not going to make much difference (yes it might affect the valve guides and valve stem oil seals eventually, but likely to burn out a valve long before you have to worry about those).
Think Yamahas started burning oil when they moved over to slipper pistons, so my guess would be that the issue is pistons and / or rings.
To be honest I would just live with it. Although if you are using a 0w40 or 5w40 oil I would switch to a 10w40 and also clean out the crankcase breather.
| SimonB |
 SimonB Brolly Dolly
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
