 mr_pete Trackday Trickster
 Posted: 23:12 - 18 Apr 2006 Post subject: Hayabusa front brake lever/brake light problem... |
T'would appear my '99 Hayabusa brake lever switch is knackered. Rear brake pedal causes light to come on, front brake lever doesn't.
I've had the lever off the handlebars and disconnected/reconnected the switch, (having wiped it) - no joy.
Now, given that I use both brakes all the time, I've only just noticed after sitting in front of a car thinking "hmm, why isn't he lighting up red?!"
I am now a little worried it's been like that since I had the braided hoses installed a month or two ago (which would have meant they had the cylinder and levers off).
The starter switch and front lights (and kill switch) all share a wiring line off the throttle, with the brakes, and everytying else behaves, so it's not likely to be a kinked wire. The brakes have a little bit of wire running from the lever/switch into the throttle body somewhere (and the brake switch can be disconnected), and I'm hoping it's just that little bit of wire.
Could this be a dead contact on/in the lever, a dead switch, or (more annoyingly) a broken wire somewhere else (meaning potentially a replacement cable and lots of fiddling)?
I don't have any testing kit, so besides trying to "short" the brake switch and seeing if I get light, I can't prove much! ____________________ Sans bike |
 sickpup Old Timer
 Bezzer World Chat Champion
