| firefox |
 firefox World Chat Champion
 Posted: 01:04 - 20 Apr 2006 Post subject: |
how about start off slow then just wack the throtle open in first
or maybe just wack it open from taking off ? you should watch that superbike movie on how to wheelie i dont know the link sorry, there has been psots on here about it tho.
edit: https://www.bikechatforums.com/viewtopic.php?t=18305 |
| Shaun |
 Shaun Likes 'em bent
 Posted: 01:09 - 20 Apr 2006 Post subject: |
| G |
 G The Voice of Reason
| extreme3d |
 extreme3d World Chat Champion
 Posted: 01:18 - 20 Apr 2006 Post subject: |
You really shouldn't need to 'clutch' nor 'back off then back on again' a 600+cc bike into a wheelie. It should lift quite happily in first by just rolling gently foward and then going to full throttle fairly sharply. As soon as the revs hit the powerband the front will lift. Keep the throttle pinned and you will eventually flip right over, also first gear is too sensitive between engine braking and lifting. So the trick is to get into second gear as soon as possible/comforable. You don't need to pull your clutch in to do this - it will (usually ) clutchless shift. |
| McGee |
 McGee O RLY?
| Reevo8 |
 Reevo8 World Chat Champion
 Posted: 02:43 - 20 Apr 2006 Post subject: |
I had major troubles on a CBR600RR. Found it was easier after having a mate on the back because I got used to the front coming up easily and so it was less dramatic when I was on my own on the bike. ____________________ 05 ZX10R, (**05 WKR)  |
| numark1 |
 numark1 Scared of girls
 Posted: 09:58 - 20 Apr 2006 Post subject: |
You need to snap it in first. 600's are quite difficult to power wheelie in second.
Get to about 7-9k revs then roll off and snap it on, dont snap it back just to a set position then it will hold the wheel up and the revs will increase gradually until you need to change gear.
If it starts to come up too fast very very gently roll off a bit.  |
| Luke_Retrofly |
 Luke_Retrofly Silly Lesbian
 Posted: 10:22 - 20 Apr 2006 Post subject: |
Yes im currently lerning wheelies again on the SV, im getting comfortable with the front comming up and holding it for a few seconds. I just snap the throttle roll off a bit and then roll on a bit more to keep it up.
You just have to practis and get used to the front comming up.
No proper mingers yet, but deffo some "show off" potential to people who dont know wheelies
luke ____________________ Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want! |
| riichy |
 riichy World Chat Champion
 Posted: 12:08 - 20 Apr 2006 Post subject: |
dont be a pussy wack it open....  ____________________ .......... PLOD ............ zx636 2004 |
| riichy |
| Dark |
 Dark World Chat Champion
| bidman |
 bidman Crazy Courier
 Posted: 12:25 - 20 Apr 2006 Post subject: |
Hi, there seems to be a lot of talk about just using the engines power to get the front up. Nothing said so far about your body positioning on the bike. A bike like a zxr400 which is extremely front heavy, will refuse to wheely even if you dump the clutch at 14k with standard gearing. However if you are to stand up on the pegs lean right back tugging on the bars then drop the clutch at around 8k, if your not careful you will flip the bike completely.
Try on your 600, just standing up on the pegs and leaning back over the pillion seat, getting more weight over the back wheel and making the front lighter. I start all my wheelies on any bike I wheelie standing as it brings the front up so much easier, puts less stress on the engine and you can find the balancing point a lot easier.
Try it but take it easy, and make sure your back brake is covered as it may take you by supprise how much easier it comes up, Dan ____________________ Don't ride it, RAG IT!! |
| G |
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 12:30 - 20 Apr 2006 Post subject: |
Yoko, i'm sure Sparks'll be along any minute to put me to shame but i'll have a stab at it.
First time i rented the RR i tried a power wheelie just round the corner of the rental shop, wasn't much of a wheelie but i had a basic idea of what to do.
Find a nice level, straight empty road
Cruise along in first gear, gently accelerating to about 9 K revs
Now shut the throttle for about a second and throw it back open to about half way
The front end should lift up for about 4 seconds before running out of puff (assuming you keep the throttle constant)
DO NOT turn the handle bars in any direction, keep them as straight as humanely possible. Twisting the bars will result in a tank slapper when you land and possibly stacking it.
Each time gently apply more throttle as you feel the front end going down and you'll get it going for longer and higher.
You're at the end of the rev range in 1st now, shift into second
Good luck mate  ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
| Dark |
| G |
| Dark |
| riichy |
 Posted: 13:10 - 20 Apr 2006 Post subject: |
f*ck thats a nice wheely for a 400 fella  ____________________ .......... PLOD ............ zx636 2004 |
| bidman |
 Posted: 13:50 - 20 Apr 2006 Post subject: |
Come on riichy this guys even got the same colour bike as you. Get that front end up, Dan ____________________ Don't ride it, RAG IT!! |
| sickpup |
 sickpup Old Timer
| Sparks! |
 Sparks! Sir Tart-a-lot
| G |
| Sparks! |
| sickpup |
 sickpup Old Timer
The last post was made 20 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
