Headlight Misery
moonym20
PostPosted: 22:07 - 15 May 2003    Post subject: Headlight Misery Reply with quote
Once again things aint going right,
looking around i decided to go and grab some 35/35 halogen bulbs, i went and ordered them and they arrived this morning. they look nice then i notice they have the wrong fitting (three prongs rather than bosch).
I decicded to have at look at my current headlights any way and see how hard they will be to change Shocked
I managed to undo the spedo cable on the clocks then unscrew them, then at the back i'm going through hell trying to get all the electrics out, the white clip n the black clip came out after a while but the purlple wire and the (multi?) other colourerd wire won't budge n i don't wana risk breaking them....can anybody offter some help?
the space to work on the Headlights is very tight, am i correct in saying that i just unclip all the wires on the headlight fitting and then rotate it so it will come out??
Joe
moonym20
PostPosted: 16:24 - 16 May 2003    Post subject: Reply with quote
anybody?
TiN
Pocket Tin
PostPosted: 16:36 - 16 May 2003    Post subject: Reply with quote
Umm, you usually don't really have to take off any of the connectors (or even the rubber thing), just rotate the light fitting anti-clockwise and it should come off, then you can take out the bulb. (This isn't specific to any bike BTW, so it *may* differ)
TiN
dotgems.net
Guest
PostPosted: 16:46 - 16 May 2003    Post subject: Reply with quote
sorry, it is an NSR, just found the sapce to work in very tight and removing the clocks is a bugger, like I said my only problem is that pink wire, it looks like its on a male-female connector but i didn't wana pull too hard in case i broke the wire and buggerd things up
cherz
TiN
Pocket Tin
PostPosted: 17:27 - 16 May 2003    Post subject: Reply with quote
Yeah, I did assume that it was for an NSR, but the principle should still be the same - you shouldn't have to unplug anything, just try to unscrew the bulb holder (big round black thing covered by a rubber domey thing).
TiN
dotgems.net
The last post was made 23 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 42.74 Kb
