Removing tyres
Slinn84
PostPosted: 17:08 - 21 Apr 2006    Post subject: Removing tyres Reply with quote
got a brand new tyre on an old knackered wheel.
got a bald tyre on the current bike so i need to take the brand new tyre off the old wheel
i've borken the seal and got the tyre to sit in the middle of the wheel but i cant leaver the tyre out so i can remove it.
any tips?
i have no other means of transport and my local garage is quite far away so i'd rather get it off myself then take it somewhere (plus i need the experience)
Ichy
PostPosted: 17:15 - 21 Apr 2006    Post subject: Reply with quote
If you managed to break the bead then getting the tyre off is just a matter of a couple of tyre levers, rim protectors (I use a bit of leather) and brute force.
Try using washing up liquid and water all around the rim, just be careful of flying tyre levers!
firefox
PostPosted: 19:46 - 21 Apr 2006    Post subject: Reply with quote
i just got a tyre off ma old wheel with screw driver and if i can do it you can Wink
Richard1987
PostPosted: 19:57 - 21 Apr 2006    Post subject: Reply with quote
Does this work for tubeless tyres ? like the ones on small scooters
i have both in need of tyre removal / refitting Crying or Very sad
add me to your msn messenger contacts : [email protected]
firefox
PostPosted: 20:12 - 21 Apr 2006    Post subject: Reply with quote
i just did it on a tubless scooter tyre
Slinn84
PostPosted: 15:21 - 22 Apr 2006    Post subject: Reply with quote
well i finally did it
took a bit of my finger off as well as the tyre but its all done
just a case of leavering a bit of the tyre bead out at a time over the wheel rim and hoping it doesn't pop back in when ya try another section
i did this on a 120/60 tyre so scooter tyres should be easy enough
dont think i'll have a go at the 160/60 rear tyre just yet
PostPosted: 15:35 - 22 Apr 2006    Post subject: Reply with quote
The trick is to make sure you keep the bit of the bead you aren't working on pressed right down into the dip in the middle of the wheel.
The last post was made 20 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 50.94 Kb
