Clunking gearbox
rK@NE
PostPosted: 20:37 - 21 Apr 2006    Post subject: Clunking gearbox Reply with quote
Just recently I've noticed that when I change gear I'm getting quite a noisey *cuurlunk*between Neutral->First->Second. It doesn't happen all the time, sometimes everything slots in smooth but 95% of the time I'm left wincing at the noise Sad
I've checked wheel alignment, chain tension and the clutch cable and they all seem within tolerance. When I had the wheel off last I noticed the chain had a few tight spots in (it had been left outside over winter) would this cause noisey gear change?
tonyyzf
PostPosted: 21:36 - 21 Apr 2006    Post subject: Reply with quote
could do, if the chain is tightening up at the point you change gear. Get a new chain and sprocket kit fitted and keep it lubed
NSR Mick
PostPosted: 21:38 - 21 Apr 2006    Post subject: Reply with quote
Maybe the clutch plates need changing.
Guest
PostPosted: 21:47 - 21 Apr 2006    Post subject: Reply with quote
Cush rubbers in the sprocket carrier on their way out?
Kram
PostPosted: 16:01 - 22 Apr 2006    Post subject: Reply with quote
check oil level Thumbs Up
When it gets low on my FZR gear changes between these gears get loud and clunky. Which reminds me.... i must do an oil change Shocked
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
bidman
PostPosted: 18:08 - 22 Apr 2006    Post subject: Reply with quote
Hi, as many have already said, it sounds like a simple clutch problem. Give it some fresh oil and check the clutch plates etc... Dan Thumbs Up
Don't ride it, RAG IT!!
The last post was made 20 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 46.67 Kb
