elbow grease on the end can...
biggaz
PostPosted: 18:28 - 23 Apr 2006    Post subject: elbow grease on the end can... Reply with quote
ive been doin some serious polishing on my can using autosol (i think its called)
looks nice n shiny from a distance but up close ive got little dots everywhere, to me it looks like corrosion but im not sure.
to the touch the surface feels perfect like glass.
the can looks to be stainless.
anybody else dealt with this or have any ideas?
id love a like-new appearance on it.
rK@NE
PostPosted: 19:03 - 23 Apr 2006    Post subject: Reply with quote
You might want to try giving it some love with fine grade (1500) wet and dry and then back on with autosol Thumbs Up
0ddball
PostPosted: 19:45 - 23 Apr 2006    Post subject: Reply with quote
First try some tar remover and if that doesn't work rub it lightly with one of these washing up scourers and some soapy water.
https://www.arix.it/webadmin/include/imgviewer.asp?ID=568
craigs23
Mr Muscle
PostPosted: 10:02 - 24 Apr 2006    Post subject: Reply with quote
Might be down to heat if there's nothing on the surface. The top of my headers are suffering from it a little and won't polish out using normal methods (i.e. general polishing). If it's ingrained into the metal, you may have to polish off the top surface - which means wet'n'dry or something as abrasive - seems a bit harsh to me though. Tar splatters would normally polish out quite easily - even from paintwork, using a light use of Brasso or finer (I tend to use Belgom Alu for this kind of use).
What kinda can is it - anything I can't polish out I tend to replace - exhausts can be easily recovered if need me.
extreme3d
PostPosted: 16:51 - 24 Apr 2006    Post subject: Reply with quote
It's just tar spots. Keep polishing and they will rub away with some hard pressure. Failing that and for a quick solution try some cellulose thinners and/or meths.
biggaz
PostPosted: 18:34 - 24 Apr 2006    Post subject: Reply with quote
its a micron can, identicle to the one at the top left of this piccy
https://www.feridax.com/images/micron-cans.jpg
ill try sum thinners and see what happens, looks brand new apart from these spots.
The last post was made 20 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 47.04 Kb
