Leeking radiator
Mr.Everready
PostPosted: 18:39 - 21 Apr 2006    Post subject: Leeking radiator Reply with quote
I was out on the bike today and after I stopped the left side of the bike (fairing and engine cover) was covered in light coloured liquid. First off I though that someone had kicked a bottle in the bikes direction and the contents spilled over the bike. When I got home I took off the fairing and the residue was over the front of the engine and filter.
So I've obviously got a leek on my radiator somewhere. Whats the best way of patching it up if I can find where the leek is coming from ?
Does Radweld (?) work the same on bikes as it does on cars ?
Cheers.
ZRX61
Victor Meldrew
PostPosted: 18:43 - 21 Apr 2006    Post subject: Reply with quote
Until you find the actual leak you have no idea if it's the rad or just a loose hose clamp etc.... Be a bit stupid buting a new rad if all it needs is a half turn on a hose clamp..
Wash ALL the residue off & then fire the bike up so you can see where the leak is.
Mr.Everready
PostPosted: 18:46 - 21 Apr 2006    Post subject: Reply with quote
I'm pretty sure its not a hose but I'll check again. There seems to be a small bit of green gunk at the very bottom corner, whether that is where it is coming from I don't know.
cagiva gezzer
PostPosted: 19:31 - 21 Apr 2006    Post subject: Reply with quote
Open the filler cap when it's hot. If it hisses and sprays boiling liquid over you the system is holding pressure and you have no leak. If it doesn't hiss you've got a leak.
So, burnt hand = good radiator. Thumbs Up
Rhino.
PostPosted: 04:13 - 22 Apr 2006    Post subject: Reply with quote
green gunk sounds like a leak Thumbs Down bummer dude
www.tribetattoo.co.uk
Finglonga
PostPosted: 12:22 - 22 Apr 2006    Post subject: Reply with quote
From personal experience Holts Radweld isn't as good as the Barrs stuff. The one I used to use was called(by the trade) Barrs dog shit as it was a block you crumbled into the header tank, it has never let me down unlike radweld. But i am not sure you can still get it. Confused
Theres always egg white...........showing my age now! Shocked
Andy Sez....
F.Y.Y.F.F.
True Blue
PostPosted: 18:54 - 24 Apr 2006    Post subject: Reply with quote
I've got a coolant system compression tester thingy, I'm not sure if it will fit on the rad on a bike though. Thinking I'll dig it out later and have a check.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
Mr.Everready
PostPosted: 19:52 - 24 Apr 2006    Post subject: Reply with quote
I put some of the Radweld stuff in and it seems to be holding ok. There was a small hole up near the horn and a wee leak down to the right. I've done 150 miles since it went in, so its fingers crossed.
True Blue
PostPosted: 20:08 - 24 Apr 2006    Post subject: Reply with quote
Cool, well if it gets worse let me know. Thumbs Up
The last post was made 20 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 59.86 Kb
