Bike derestricting problems... (with pics)
JonB
Afraid of Mileage
PostPosted: 19:46 - 25 Apr 2006    Post subject: Bike derestricting problems... (with pics) Reply with quote
Hello,
Well what started off to be a simple getting rid of the baffle in my exhaust (of which I couldn't do after 3 drill bits were snapped and it is proving to be difficult) me and my Dad thought we would have a go at derestricting the bike, so we took the tank off, which incidentally was very easy, I have no knowledge of bike mechanics at all, but fortunately Dad has a little bit of knowledge, so we got the tank off, well partially...
https://img.photobucket.com/albums/v93/JonBod/2006_0425005800.jpg
So with that we took off the carb headers and pulled the vacuums out, this was easy enough...
https://img.photobucket.com/albums/v93/JonBod/2006_0425001800.jpg
But we for the life of us can't tell the difference between the derestricted one and the normal one...
Can you?
https://img.photobucket.com/albums/v93/JonBod/2006_0425002800.jpg
The one on the right is the "restricted one"
Initally I thought the green piece in the next bit would be the restrictor cause it went the whole way down and seemed to block off that hole in the middle...
https://img.photobucket.com/albums/v93/JonBod/2006_0425003800.jpg
However without it the springy thing won't stay on it, god knows what it is there for though!
https://img.photobucket.com/albums/v93/JonBod/2006_0425004800.jpg
So my question is, if anybody else owns a Bandit and had a Suzuki Restrictor kit, this is not an FI Kit AFAIK, how the hell is it restricted? Does the carb headers look different to you? Am I missing something completely? Would it be washer restricted?
Thanks, Jon.
Jack_Cheese
PostPosted: 19:49 - 25 Apr 2006    Post subject: Reply with quote
Take the carbs off, and there should be washers between the carb and the engine block i think. At least that's the way i've always understood it.
By the way, fuel injected bikes don't have carbs, so you're certainly right about it not being EFI
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
JonB
Afraid of Mileage
PostPosted: 19:50 - 25 Apr 2006    Post subject: Reply with quote
I mean FI International, the company that restricts most bikes. This is a Suzuki Restrictor kit. Smile
cagiva gezzer
PostPosted: 20:00 - 25 Apr 2006    Post subject: Reply with quote
Thought i'd be clear that it's the green bit preventing the slide / diaphragm from opening fully. Hence, you'd only get X% of the total opening.
JonB
Afraid of Mileage
PostPosted: 20:02 - 25 Apr 2006    Post subject: Reply with quote
So what's the deal with the spring then Confused
Rookie
PostPosted: 20:15 - 25 Apr 2006    Post subject: Reply with quote
I know this isn't at all helpful, but here's hoping you'll be derestricted for the May Day run now! Mr. Green Thumbs Up
cagiva gezzer
Without wishing to be funny, but i fear for your bike if you're not grasping this.
AFAIK know, i've never worked on those nasty things called four strokes, the spring pushes the diaphragm down. Low air pressure on the engine side of the carb causes the diaphragm to be pulled up.
In short, swap it the diaphragms. Might draw a piccy...... Confused
phantomtek
Lil Joe Tek
PostPosted: 20:17 - 25 Apr 2006    Post subject: Reply with quote
Don't know if it's any help but this is how the ER-5 is restricted, I seem to remember dodsi giving away washers for his Bandit so you may want to check here.
JonB
Afraid of Mileage
PostPosted: 20:19 - 25 Apr 2006    Post subject: Reply with quote
Without wishing to be funny, I didn't know I had to have a mechanics degree to own a bike. Wink
All I asked was what the spring did, in hope of learning something and derestricting my bike. Yes I know I'm a novice when it comes to looking at bike engines, but I still maintain it as much as I should, so I don't think not knowing what a spring on a carb does is going to affect my bike greatly.
Anyway, so what shall I do? Just take the spring out or what? Will there need to be washers in the carbs, or could it possibly just be restricted like this?
cagiva gezzer
PostPosted: 20:30 - 25 Apr 2006    Post subject: Reply with quote
https://www.nightrider.com/biketech/images/cv_carb_cutaway.jpg
Normal carb above. CV carb if you're picky.
How it works -
The butterfly (10) opens and allows air in.
Differences in air pressure in areas (1) & (2) causes the diaphragm (3) to rise. The spring fights this rise. As the diaphragm rises it allows more fuel in.
= more power and revs.
Attached is your restricted carb. The green spacer prevents the diaphragm from going to the top. Prevents the needle from allowing fuel to flow. Same as only wonding the throttle back 75%.
From experience, it's when people play with things and don't put all the things back in that gives rise to other issues.
So, keep spring, junk green parts. You might have something between the carbs and the head, but i very much dobt it.
JonB
Afraid of Mileage
PostPosted: 20:46 - 25 Apr 2006    Post subject: Reply with quote
Sorry for my post earlier and sorry for pestering you, but the green thing made sure that the spring didn't "fall" over as it clipped over the green thingy. So will it just stay upright on it's own accord, or do I need new springs or something.
phantomtek
Lil Joe Tek
PostPosted: 20:58 - 25 Apr 2006    Post subject: Reply with quote
If it's any help on mine it goes down into the carb itself and the groove type thing on the black lid keeps it upright once you put it back on.
NSR Mick
PostPosted: 21:09 - 25 Apr 2006    Post subject: Reply with quote
Have a look down the carbs and see if you can push the slides all the way up, otherwise i think your green friends may have something to do with it as every bike I've had the springs are a bitch to get to go in without springing out. Thumbs Up
cagiva gezzer
PostPosted: 21:20 - 25 Apr 2006    Post subject: Reply with quote
Closest i can find
I say slap it all back in. The springs shouldn't "fall over" as they should sit square.
DynaMight
PostPosted: 01:28 - 26 Apr 2006    Post subject: Reply with quote
I've only had experience with washer only type restrictions myself, different bikes have different restrictions but I found this:
https://www.loply.com/szr660/derestrict
Also check under the carbs, you may possibly have washers under them too (I've heard of R6's having both)
Reevo8
PostPosted: 03:37 - 26 Apr 2006    Post subject: Reply with quote
About time too Jon. You guys sound like experts in comparison to me, I just take stuff of put it back on, god knows what the names of things are.
Good luck with sorting it though mate.
And just looking at the shape of the top of the 'carb headers' it looks to me that as on my other bikes it has a shape in the top to support the spring and leave it 'tensioned'(I think I made that word up Confused ).
So whip the green fellas out and put the springs into place using the shaping in the carb header caps to hold the springs in place. That is how all of my bikes have been put together I think. Give that a go link it up and see if it will rev to the redline.
Probs best to try and whip the carbs off first and see if they have the washers in there too before you put it all back together. Likely it doesnt have them though due to the prices of the Suzuki kits.
Give it a try Jon.
Hope it works mate.
05 ZX10R, (**05 WKR) Very Happy
Dot_Comm
PostPosted: 10:56 - 26 Apr 2006    Post subject: Reply with quote
PM Kara. She just derestricted her bandit (she sent me the washers but they got lost in the post Sad ) so she might be able to offer you some advice.
Edit: oh hang on, hers was an FI International kit so perhaps she can't help. But try it anyway.
Rach
JonB
Afraid of Mileage
PostPosted: 11:12 - 26 Apr 2006    Post subject: Reply with quote
Thanks for the help guys, I suspect that it is those green things, but I will go into the Suzuki Dealership today just to check...
DynaMight
PostPosted: 11:38 - 26 Apr 2006    Post subject: Reply with quote
Take them out first, you'll get there faster Smile
Walker
PostPosted: 11:51 - 26 Apr 2006    Post subject: Reply with quote
I don't know whether this is the same at all, but the (FI) restrictors on my K3 Bandit were between the carbs and the engine block, I had to pull the carbs away from the airbox and then from the engine block and lever the restrictors out with a screwdriver. Just be careful though, i had about as much mechanical knowledge as you and didnt quite put my carbs back on properly...
Having the restrictors out completely transforms the bike, with a massive kick of acceleration from 8,000-10,500 revs. No more struggling to get to 90! Its such a laugh with them out, youll never understand why you had them in in the first place Smile
Reevo8
PostPosted: 13:16 - 26 Apr 2006    Post subject: Reply with quote
When you get a Suzuki restrictor kit they give you the bits you need to replace so he knows it isnt washers alone if at all.
Then yellow marked lids in this piccy will hold the springs in placejust take the green bit out and check for the carb washers. Are wasting ya time going dealers IMO.
JGY6000
PostPosted: 16:03 - 26 Apr 2006    Post subject: Reply with quote
i got mine off a mate, the packets they came in suggest they were from suzuki, i fitted them exactly as the original carb sliders were fitted and when i looked the only diff i could see was the two holes, hope this helps
https://www.bikechatforums.com/download.php?id=33061
The last post was made 20 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 118.49 Kb
