Clutchless up-shifting?
jonboy22
PostPosted: 17:19 - 25 Apr 2006    Post subject: Clutchless up-shifting? Reply with quote
Can somone explain clutchless up-shifting to me?
I'm assuming its something to do with getting the revs at just the right point prior to engaging the next gear but I thought it could only be done on the way down?
I think in cars you can shift down from 4th to third regardless but again I've never heard of going up?
Oh and just for reference purposes it was mentioned in a BIKE magazine review of a K4 GSX-R600
On a separate note does anyone know where to get ceramic rearsets? Or are they a myth?
Barry_M2
PostPosted: 17:25 - 25 Apr 2006    Post subject: Reply with quote
Do search mate, this has been covered a few times. Thumbs Up
no_shad
PostPosted: 23:21 - 25 Apr 2006    Post subject: Reply with quote
Your car is most likely to have a synchromesh gearbox, a different kettle of fish compared to the sequential box in most motorbikes.
NSR Mick
PostPosted: 23:23 - 25 Apr 2006    Post subject: Reply with quote
dead easy you just need to apply pressure on the gear lever whilst backing of the throttle slightly, comes naturally after a bit of practice. Thumbs Up
colin1
Captain Safety
PostPosted: 01:39 - 26 Apr 2006    Post subject: Reply with quote
you can do clutchless changes with a car, you just need to match the revs to the speed of the car
all a clutch does is make the two match
veeeffarr
PostPosted: 03:22 - 26 Apr 2006    Post subject: Reply with quote
Surely the clutch actually disengages the final drive from the engine, so you're slotting cogs together rather than easing them onto each other when clutchless changing?
I am a mechanical fucktard though, so that may be lies.
Barry_M2
PostPosted: 10:24 - 26 Apr 2006    Post subject: Reply with quote
No it doesn't.
kawakid
PostPosted: 10:28 - 26 Apr 2006    Post subject: Reply with quote
Only do clutchless going up, otherwise you'll screw your engine.
Get your revs up so it feels like it needs a change, turn the revs off quickly and at the same time push up with your left foot and then back
on the revs.
I can do it, but there's not much point.
I've a twin and a 4.
NSR Mick
PostPosted: 10:34 - 26 Apr 2006    Post subject: Reply with quote
Not on an ER-5 maybe. Thumbs Up
colin1
Captain Safety
PostPosted: 14:09 - 26 Apr 2006    Post subject: Reply with quote
Barry_MC21 wrote:
No it doesn't.
the clutch doesnt slot things together
when clutch plates are apart, pistons and cranks can spin without being connected to the wheels at all
when the clutch plates are together, the drive is transferred to the wheels
the bit in between is like when you apply your brakes
your brake pads are stationary and when you apply your brakes to the discs, it reduces their relative speed to the pads until they are going at the same speed, (ie stationary)
clutch plates do the same thing except usually neither the plates attached to the wheels or the plates attached to the engine are stationary.
if you pulled the clutch in and hit your kill switch, and then released you clutch, you would lock the back wheel as then the engine plate would be stationary like a brake pad, and the plate attached to the wheels would be like the brake disc attached to your front wheel.
so you can make the input to gearbox rpm match the engine output rpm by just getting the revs right rather than using the clutch
when people blip the throttle they are getting the two to match as closely as they can, then they use the clutch to make it a perfect match
you can still change gear even if your clutch doesnt work
my dad drove a vw camper van through the drakkensberg mountains without a working clutch by matching the revs
no_shad
PostPosted: 20:33 - 26 Apr 2006    Post subject: Reply with quote
Barry_MC21 wrote:
No it doesn't.
You are describing friction and inertia, I could accelerate up to 120 on my sv, disengage the clutch, drop to 1st, redline the engine, release the clutch and still lock the rear wheel up. What does that prove? Apart from engine braking being greater than tyre grip, not much, it's a poor analogy.
Toby is correct, all a clutch does is disengage drive.
The engine spins all the time, whereas the rear wheel needs to stop. Thumbs Up
How can you blip the throttle without using the clutch?
I assume their road speed blips too? Confused
When changing gear you basically need to take the load off the cogs you are engaging/disengaging, hence backing off the throttle or grabbing the clutch.
Matching revs on a downchange gives a smoother change of gear as you are not spinning the engine up using the rear wheel drive, this results in less chance of locking the rear, reduced wear etc. If you are not using the clutch when changeing down, how do you match revs?
my dad drove a vw camper van through the drakkensberg mountains without a working clutch by matching the revs[/quote]
I don't know if the camper had a synchro box, but he would probably already have to double clutch for smooth gear changes anyway.
Try driving an early mini for a similar experience. Smile
The last post was made 20 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 71.96 Kb
