2 Stroke big end
Gazdaman
I did a trackday!!!
PostPosted: 00:17 - 26 Apr 2006    Post subject: 2 Stroke big end Reply with quote
Well, turns out the big end's seized on the MZ.
I suspect this is due to me not having plugged a few holes properly that I should have done.
Anyway, is it repairable? What are the chances the crank's wrecked?
Not a huge deal cuz a new engine is cheap, I would like to salvage this one as a spare though.
New big end bearings? Just trying to think what would seize the big end, yet not seize the bore..
Gaz
Guest
PostPosted: 14:59 - 26 Apr 2006    Post subject: Reply with quote
Dunno about MZ's, but for most Jap strokers you can get a rod/bearing/crankpin set and just have the crankshaft re-built.
lee125
PostPosted: 15:05 - 26 Apr 2006    Post subject: Reply with quote
could be lack of gearbox oil Thumbs Up
cbt passed Smile 01/07/2006 bike:92 dt 125 and 96 honda cr 250
theory:PASSED! A2 test:PASSED 08/11/2006 restricted to 33bhp for 2 years
Barry_M2
PostPosted: 15:07 - 26 Apr 2006    Post subject: Reply with quote
You might just get away with bearings, but you should measure the crank thickness to see if its within the service limit. I'm not sure, but you might be able to grind the crank and fit a smaller bearing?
Barry_M2
PostPosted: 15:09 - 26 Apr 2006    Post subject: Reply with quote
Not in a 2-stroke.
finpos
PostPosted: 15:44 - 26 Apr 2006    Post subject: Reply with quote
Bottom end seizure probably due to lack of lubrication - not enough oil in the pre-mix or oil pump borked. Can be helped along by general overheating (i.e. the top end was partially siezed), but if the engines done enough miles it may just have been brought on due to wear. Or some idiot (me) has fitted a pattern bearing supplied with a dust-shield and not removed it.
Re-building the crank with new bearings and seals (old ones may be heat damaged) should be pretty straightforward. It's not like a plain bearing setup in a 4 stroke where you need to worry about the actual crank being worn out - unless you really knackered it!
finpos.
cagiva gezzer
PostPosted: 17:36 - 26 Apr 2006    Post subject: Reply with quote
Big ends go as they get a hell of a lot of stress. When you rebuild stroker cranks you get a whole new rob with crank pin and bearing, so it's unlikey the crank webs are unuseable.
John Robinson Wrote
Crankshaft and big end bearings. Usually speed related failure of the big end cage. May be caused by overheating or insufficient lubrication or by the rollers skidding and increasing their working clearance. There are also problems with crankshaft twisting
So, what was it like last time it was stripped? Clearances and all that.
Knackered small ends can also take out bottom ends.
It's important to understand just how stressed big ends are. They don't have a constant rotational speed (at any given rpm) like the mains or gearbox gears. The rotational speed oscillates due to the angular swing of the con rod.
i.e. they go fast (0degrees) - slow (90 degrees) - fast (180 degrees) slow (270 degrees)
Gazdaman
I did a trackday!!!
PostPosted: 18:06 - 26 Apr 2006    Post subject: Reply with quote
Never been stripped before, and yes it may have been low on gearbox oil, but that shouldn't be lubricating the big end, so not an issue.
I think my mixture was ok, slightly too rich with 2t oil, but that shouldn't have caused a seizure.
I'll phone burwin tomorrow, see what light he can shed on it, I suspect cost of repair will be more than the cost of a new engine though.
Might just be usefull to salvage parts from.
Gaz
Guest
PostPosted: 19:01 - 26 Apr 2006    Post subject: Reply with quote
*checks watch and waits for someone to say "too much oil means it's actually too weak"*
NSR Mick
PostPosted: 19:21 - 26 Apr 2006    Post subject: Reply with quote
(a whole 20 minutes Laughing )
Depends whether you are running premix or pump though. A weak mixture (fuel) wont sieze a big end, wear and tear or a lack of oil will.
The last post was made 20 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 65.79 Kb
