| killa |
 killa Won't Shut Up
| killa |
 killa Won't Shut Up
| phill.c |
 phill.c Traffic Copper
 Posted: 13:25 - 27 Apr 2006 Post subject: |
well my cousins cbr125 went funny so he had a look, it was geting a spark fuel was ok pistons fine, oil was ok basically everything was as it should be the electrics were ok, but wouldn't fire for shit and it was one of the coil or coild can't remember then went.
hope that helps ____________________ CBR400RR the funs started - Honda MTX 125 ongoing project when i can be arsed  |
| finpos |
 finpos World Chat Champion
 Posted: 14:45 - 27 Apr 2006 Post subject: |
On a 4-cylinder bike, one duff pickup coil would cause a pair of cylinders to drop out, two would stop it running at all.
I never heard of pickup coil going duff without something more serious and fundamental having happened (like the alternator bombing).
Or do you mean the ignition coils breaking down? This can happen with heat/moisture and can cause annoying and intermittant misfires. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| killa |
 killa Won't Shut Up
 Posted: 15:21 - 27 Apr 2006 Post subject: |
I think they are breaking down....
Ok, i hope i can make this make sense, i might miss something out I have been doing this work with a trained mechanic.
The bike was a bit spluttery before, a bit of a flat spot so to speak.
The bike backfired slightly when letting off the throttle at speed.
I was going to get the bike looked at.
Before i got her into the garage, i was coming home from work, i filled her up, started to go down the M'way and the thing lost all power. She cut out and i sat at the side of the road, starting it was impossible.
I suspect a problem with fuel as the Haines pointed to carbs.
I had the carbs out and checked all fuel lines.
The carbs were pretty clean, but i found a slash in the vacum pipe to the tap, so i guess that would have caused the bike some problems.
I replaced the pipe and put the carbs back on, the bike wouldnt start.
Took carbs off, and plugs this time.
Front two had broken down, this was possibly the result of me trying so hard to make it start plus something else.
Got new plugs, the thing fired first time, but it kept cutting out.
Eventually after some tweaking i got her ticking over, she sounded like she had done before.
But she wouldnt pull any weight, you'd give it some throttle and she cuts out. Everytime.
So now, after all the checks, the symtoms point to faulty electrics, hense the plan to check and replace the Pickup coils. ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
| finpos |
| killa |
 killa Won't Shut Up
| map |
 map Mr Calendar
 Posted: 16:48 - 27 Apr 2006 Post subject: |
If your carbs/fuel checks out you could try checking the alternator.
Check check is with one of these (from the likes of Maplins).
https://www.maplin.co.uk/images/Full/10162i0.jpg
However, if your coils are failing then by reving the bike the problem (in theory) should go away. As you're increasing the current it'll jump easier over any gaps and therefore you wouldn't see it.
BTW when the ignition coils on my GT550 went a symptom was it loosing the cyclinders as stinkwheel said but also the rev counter needle was swinging all over the place and bore no relation to how the bike sounded. The alternator was ok though.
Just some thoughs  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
The last post was made 20 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
