er5 clunky gears in 1st and second
stooster
PostPosted: 00:02 - 28 Apr 2006    Post subject: er5 clunky gears in 1st and second Reply with quote
before i bought my er5 i read about a horrible clunk when going in 1st and then up to 2nd.... my bike does excactly this......does anyone know why and is there a way of making it stop!!!
Lawnie
PostPosted: 11:02 - 28 Apr 2006    Post subject: Reply with quote
Yeah my CBF500 does this. AFAIK it's an inherent thing with Honda twins. There's no reason why similar bikes wouldn't suffer as well. I don't think there's anything wrong with it.
Try giving it a few more revs/speed before changing, this often reduces the clunkiness (and no, not simply because the engine's making more noise).
willi
PostPosted: 13:39 - 28 Apr 2006    Post subject: Reply with quote
try adjusting your chain a loose chain has the effect you are describing.
wat goes around comes around.
mchaggis
PostPosted: 14:23 - 28 Apr 2006    Post subject: Reply with quote
Make sure your chain isn't too tight or too loose, make sure the clutch is in the correct adjustment and make sure you haven't too little or too much engine oil.
I must not be a troll...
Mmmm, Guinness
MikeH
PostPosted: 20:51 - 28 Apr 2006    Post subject: Reply with quote
Change the oil.
I had on my KLE500 (same setup as the ER5) in 1st,2nd & 3rd but after an oil change it made a marked improvement, only really 1st when cold.
Mike Thumbs Up
Busa Junkie
stooster
PostPosted: 23:42 - 28 Apr 2006    Post subject: Reply with quote
i do need a new chain as it has a couple of tight links that i have freed off.....but the clunk to 1st happens without the chain moving......regarding the oil i changed it about 3 weeks ago...
it only happens in 1st then to second and i read online on some er5 reviews that there is a horrible clunk for 1st and 2nd on the er5 ...just hoping an er5 owner has tried to solve it or maybe you have an er5 which dosent have this problem meaning it is fixable...
cheers for the help
kawakid
PostPosted: 23:59 - 28 Apr 2006    Post subject: Reply with quote
I find when I've had choke out it does that the big clunk and I sort of know when its going to do it.
Also be careful on you gear changes down from 2nd to 1st, my previous bike was more foregiving.
I think i've just got used to how it is and accepted it.
I've a twin and a 4.
iCraig
PostPosted: 00:11 - 29 Apr 2006    Post subject: Reply with quote
Accept it, ER-5 engines have notoriously clunky gearboxes, its just inherent and nothing to worry about!
reeso
PostPosted: 16:59 - 29 Apr 2006    Post subject: Reply with quote
It,s to do with the mech that stops you selecting 2nd gear when stopped.It is possable to strip gearbox 'chuck it away but it.s not worth bothering. My ER5 @ZZR are both the same.
Hang loose, Stay cool, Admit nothing.
stooster
PostPosted: 21:07 - 29 Apr 2006    Post subject: Reply with quote
today before leaving work i revved the engine to about 3k from stopped in neutral and put it in 1st......got the biggest clunk ive had yet.......BUT after this ...the bike dropped into 1st sweet as a nut....i rode home about 2 miles then tried it again and it went from neutral to 1st sweet as about 6 times..........wondering if there is some slight misalignment that works loose and ive realignes somet in the box or not...very strange...just have to see what its like tomoz........
cheers 4 help chappies
stooster
PostPosted: 21:08 - 29 Apr 2006    Post subject: Reply with quote
The last post was made 20 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 66.77 Kb
