Forks woes - Bent, but can't be?
loply
PostPosted: 16:08 - 30 Apr 2006    Post subject: Forks woes - Bent, but can't be? Reply with quote
Hi folks,
My forks were 100% fine but one of them was leaking a wee bit, so I stripped it and replaced the fork seal. I've done this before, its quite easy.
Upon reassmebling the fork, the stanchion would not slide once I put the guide bush (teflon coated slider) back into the fork leg. It just jammed solid.
The best suggestion I had was that the bush might be twisted or distorted, so I bought a new one... £20 down the drain. New bush made no difference.
Basically when you put the guide bush in, the stanchion jams up and wont slide. This sounds exactly like a bent stanchion.
But how? Could it be anything else? I cant possibly explain how it became bent... If I can't fix this, it might not be worth new forks, I might just write the bike off, its just too much to handle.
Im so pissed off. Simple fork seal replacement turns in to this nightmare.
Any suggestions? Neutral
Yamaha SZR660 Caution to the wind, the throttle pinned!
Bezzer
PostPosted: 16:12 - 30 Apr 2006    Post subject: Reply with quote
Only one, are you sure everything went back in the right order, I've done it wrong before now and everything locked up Embarassed
zenodamper
PostPosted: 17:32 - 30 Apr 2006    Post subject: Reply with quote
U near to London or West Sussex? I could help you by having a look - no charge by the way...
The last post was made 20 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 35.59 Kb
