Can CDI's Partially Fail
Moshman
PostPosted: 00:15 - 02 May 2006    Post subject: Can CDI's Partially Fail Reply with quote
My GPZ1000 still won't start. I have checked coils they are fine, i have checked pulser coils they are fine.
I am getting no negative feed to one of the coils. This is fed straight from the CDI it does keep powering up every so often.
The other coil is getting feed and is sparking everytime. I have had the multimeter on the positive feed to the coil and on the wire as it leaves the CDI and there is no voltage there unless i engage starter then it goes up to 15V then drops straight to zero.
My question is can a CDI partially fail, ie supply one coil and not the other. I was always under the impression a CDI unit either works or does'nt.
Any input would be greatfully received as the weather is getting better but my bike isn't.
Moshman
PostPosted: 21:02 - 02 May 2006    Post subject: Reply with quote
Does anybody know of anywhere near Chesterfield that can test my CDI
iCraig
PostPosted: 23:39 - 02 May 2006    Post subject: Reply with quote
Rather than the CDI sounds like a short or a bad connection to me somewhere.
bish777
PostPosted: 23:49 - 02 May 2006    Post subject: Reply with quote
check the earth from the coil. Put the negative terminal direct to ground and see if it works.
GSXR1100J
Moshman
PostPosted: 02:15 - 03 May 2006    Post subject: Reply with quote
Its the earth to the coil that is suspect. But goes straight from the CDI to the coil. If i put it straight to ground and it sparks does that mean my CDI is faulty
fatboyslim
PostPosted: 10:51 - 03 May 2006    Post subject: Re: Can CDI's Partially Fail Reply with quote
I have the same problem with my bike. I get a weak spark when the started is turning then it disapears. I have been told by a dealers workshop that the CDI is faulty, But am having problems getting one as its a chinese import.
best of luck getting your machine going.
Regards FBS
My name is gwyn and i am from wales
finpos
PostPosted: 10:54 - 03 May 2006    Post subject: Reply with quote
Assuming you have two coils and two pickups, then what is inside your cdi box is actually two cdis in a single package. So, yes, one half of it can fail.
The "earth" wires between the coil and cdi are actually trigger wires - in normal operation they will be pulsing 12V-Earth every time the pickup reaches it's firing point, and it's this pulse which will cause the coil to spark. By grounding this wire, you are essentially simulating one pulse. So if you get a spark out of the plug when doing that, it should give you (some) confidence that the coil itself is ok - BUT it may still have a problem in normal operation if it cannot recover quickly enough to make the next spark.
The easiest thing for you to do is to swap over the two trigger wires between the coils and the cdis. if the fault then also swaps betweem coils, then the cdi or pickup for that side is burst (try swapping pickups next). If the fault stays on the same coil, the fault is with the coil or associated wiring gubbins.
If you do this, remember you are also trying to eliminate a problem in the trigger wires, so don't feel scared to run a couple of extra wires in parallel between the cdi and coil.
finpos.
Moshman
PostPosted: 19:16 - 03 May 2006    Post subject: Reply with quote
Thanks folks i will investigate at the weekend.
The last post was made 20 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 57.01 Kb
