Booting problems
Paul@125power
PostPosted: 11:52 - 03 May 2006    Post subject: Booting problems Reply with quote
I think my computer may have contracted a virus. I tried a lot of anti-virus software but they wouldn't shift it so I decided to format the entire drive of all files and crap which I didn't really need and lot of it was already backed up on discs (like music and pics)
I have 2 hard discs (a C drive and a D drive), Windows is installed on the C drive and my other files are on the D drive (like pics and music and videos). After formating the C drive and trying to reinstall windows on it, it kept crashing half way through the windows set up. I thought this might have something to do with the virus spreading to the other drive so I unplugged it, but the problem still occured.
I then removed both drives and replaced them with a spare hard disc that was new with not a thing on it. The problem still occured but only this time, set up completed but after it finished and it rebooted a message keeps coming up saying: 'Error loading operating system'.
I've tried reinstalling several times but this still occures, before this hapened it said that the 'NTLDR file' was missing.
Does anyone have any advise or a solution to this problem as without my home computer I am absolutly nackered.
Thanks.
If at first you don't succeed.....destroy all evidence that you tried.
Yamaha YQ100 (RIP)......Honda CBR125R
daz|n00by
The Internet
PostPosted: 12:01 - 03 May 2006    Post subject: Reply with quote
First thing is to reset your bios.
then you will need to lay your hands on a win 98 disc or floppy and do a fdisk this will cure your NTLDR problem.
you can then do a format with xp and instal, make sure you instal using ntfs and not fat32.
edit: this is the way i have fixed this problem, i,m not saying this is the only way or the best but its one way.
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
NSR Mick
PostPosted: 13:05 - 03 May 2006    Post subject: Reply with quote
Whenever I have had that error 9 times out of 10 its faulty RAM. The other times its either HDD, CPU or motherboard.
UrbanRacer
PostPosted: 13:14 - 04 May 2006    Post subject: Reply with quote
I agree with the RAM suggestion. if you have more than 1 RAM chip try using only one of them and try again. if it fals over again then take that one out and try again. if it happens again then chances are it isn't the RAM. it'll either be the CPU or Motherboard.
are you getting a blue screen of death? if so whats the error? fault in a NON_PAGED_AREA ? thats usually RAM btw
daz|n00by
The Internet
PostPosted: 13:53 - 04 May 2006    Post subject: Reply with quote
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
Cause:
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
Additional information: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter "E". This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows Operating System and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
REFERENCE NUMBER: CH000465
NTLDR is Missing.
Issue:
NTLDR is Missing.
Related errors:
NTLDR is Missing
Additional Information:
See our NTLDR dictionary definition for a complete definition on this term.
Cause:
Solutions:
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same Operating System. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c: <press enter>
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
NSR Mick
PostPosted: 15:09 - 04 May 2006    Post subject: Reply with quote
Faulty memory can corrupt stuff, so for corrupt read faulty memory.
The last post was made 20 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 61.29 Kb
