| gimpy limp |
 gimpy limp Nearly there...
 Posted: 17:26 - 06 May 2006 Post subject: Causes of misfire / stuttering at around 68 mph? |
I'm getting some stuttering if I give medium to hard throttle at around 68mph but all through-out the rest of the rev range the bike runs great at any other speed. It doesn't idle rough or pull away bad and it starts first time every time so not sure what this could be? I've only noticed it the past 4 / 5 days.
Has anyone ever had those symptoms from the early stages of a (head) gasket starting to give up maybe?
Other than that I tightened up the head bearings again the other week (I think before I noticed this misfire) and may have yanked something loose as the handlebars went back to do it.
Other than that does it sound like the carbs need fiddling with or the air filter maybe? Can the carbs alter themselves like that without me touching them? ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| firefox |
 firefox World Chat Champion
| gimpy limp |
 Posted: 22:34 - 06 May 2006 Post subject: |
my mistkae its not a misfire (Theirs no backfiring) it just stutters and theirs a major powerloss at 70.
I just tried 70 in third to see if it does it any where in that rev range and it went straight up to 70 in third smoothly without a stutter.
It's a strange powerloss, once you reach 70 as your still climbing it stutters then if you back off a tad then slowly accellerate you can reluctantly get up to 75, it does that again then you can get up to 80.
| WavyGravy |
 WavyGravy Scooby Slapper
| WavyGravy |
| TheDonUK |
 TheDonUK World Chat Champion
| gimpy limp |
 Posted: 22:45 - 06 May 2006 Post subject: |
worth giving it a go tomorrow with the air fiters off to narrow that down maybe?
I have to do almost 200 miles each way next week along the motorway mostly so it's not ideal timing, looks like i'll have to do it in 60 all the way
I just had a nosey at the fuel filter but it's so small it's hard to tell if it's dirty (its been on their around 7/8 months without a problem). I think it's fine though nothing obvious.
I did just notice the headlight keeps flicking on and off as I turn the handlebars so I think i've half yanked out a wire when i done the head bearings so it's possible i've trapped something else. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
| gimpy limp |
| Nath |
 Nath World Chat Champion
| gimpy limp |
| mr.z |
 mr.z World Chat Champion
 Posted: 23:08 - 06 May 2006 Post subject: |
mr haynes says...
"poor running or lack of power at high speeds"
weak spark at plugs or erratic fireing (section 12)
ht lead insulation failiure, my be completely unnoticeable at lower speeds
fuel/air mixture incorrect
air bleed holes blocked, clean carbs
main jet blocked
reduced fuel flow (cold be the tank breather hole?)
vaccumdiaphram split
compression low (compression test) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| WavyGravy |
| WavyGravy |
The last post was made 20 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
